06-03-2009, 04:08 PM
Super Sidecars Favourite Bike: Ducati 998(dont own one)
02 Triumph- Oil sight window wrong??
So in the past when I've changed the oil I just put oil into the bike until it's filling up 1/2 (but closer to the top) of the oil window while the bike is level. I never measured it. While browsing around this site I noticed a link for how to change the oil on a t-bird (from webbikeworkd). It stated that the site window is wrong!!
Is that accurate? have I been underfilling the oil this whole time? This guy is saying to put a 2x4 under the kick stand and measure it that way? Manual says to put the bike level?
Tried doing a search but came up with Nothing.
Thanks!!
06-03-2009, 04:16 PM
Formula Extreme Favourite Bike: Me Thunderbird of course
Posts: 590 Other Motorcycle: Toyota Landcruiser Extra Motorcycle: IT 490
I've always filled it so the sight glass is half full with the bike level, takes 3.5 litres. Never had a problem.
I believe there is no such thing as accidents. When I ride I must leave enough room for others stupid mistakes, added to that is enough room to make my own.
06-03-2009, 05:14 PM
Site Supporter Pole Position Favourite Bike: Well, Duh!
Posts: 3,650 Other Motorcycle: Can't afford two! Extra Motorcycle: Three would be insane
each to their own - manual is right WBW is less right - the glass works fine.
As an aside I always fill mine to just under the top of the glass... remember to re check after running if you are changing the filter
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
06-03-2009, 07:01 PM
Got it, thanks!
06-03-2009, 08:42 PM
Formula Extreme Favourite Bike: 1999 T'Bird Sport
Posts: 894 Other Motorcycle: 2001 Sprint ST Extra Motorcycle: 1977 T140
Oil Sight Glass.......
.... is next to useless!. A very small degree of lean off centre will provide a false reading in the sight glass. In my case, I measure out/measure in the oil when changing oil and filter. I am with Woodsie on this one 3.5 litres it is for my scoot. Used to run 4 litres with the oil level out of sight on the glass (and bike as near as practical to level). Found that with this amount in the sump the breather could not handle it. Experimentation showed that my machine 'likes 3.5 litres.
06-03-2009, 11:46 PM
Formula Extreme Favourite Bike: 1996 Thunderbird
Posts: 601 Other Motorcycle: 2000 Sprint ST
I asked this question of Ma's cycle and they stated that an oil change and filter it takes 3.5 litres, 4 if the engine gets tore down for a rebuild.
"You are either on something or onto something"........The Common Man
06-04-2009, 12:07 AM
Both are correct. The 2X4 levels the bike from side to side which is the angle of reference in the manual. A 2X4 is kind of scary to me so I put the bike on a jack after an oil change and top it off to the center of the site glass and give the bike a good once-over while it is in the air.
06-04-2009, 05:09 AM
Site Supporter SuperSport Favourite Bike: '02 T'Bird 900
Ditto. 3.5 litres with filter change.
06-04-2009, 09:54 AM
Originally Posted by ClassiclyMobile
Both are correct.
Perhaps I should clarify my "less right" statement - I essentially meant the above. i.e. that the sight glass is not wrong, but yes you should be filling it on the level, not with 2x4's or similar (i.e. less right) . With the bike level in both directions you'll find the glass works.
Mick...
06-04-2009, 10:01 AM
Grand Prix 250 Favourite Bike: 03 Tbird
Here is what works for me.
I have an 03 Tbird with a center stand. With the bike on the center stand I lift the front wheel up 1 inch. I found that a hockey puck is exactly 1 inch in width so I use that under the front wheel. The bike is now level and the sight glass works as it should. I fill to half way up the glass. With this method I no longer get oil dripping out of the airbox.
