Instrument lights stencil/fascia (not sure on the term) replacement - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-01-2009, 12:10 PM   #1 (permalink)
Hi
Hope you guys can help me.
On my '95 Thunderbird, the black plastic sheet that sits on top of the warning bulbs (shows neutral, oil, high beam, left/right signals etc) is a bit worn.
Do you guys know what the 'official' part name of this is called? Or alternatively, is it possible to make a replacement?
Many thanks,
Ian
thunderpants is offline   Reply With Quote
Old 06-01-2009, 02:05 PM   #2 (permalink)
Slinky's Avatar
Triumph call it a "Lens, warning lights".
Part # is T2502081
Slinky is online now   Reply With Quote
Old 06-01-2009, 03:18 PM   #3 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
I made a replacement out of 1/8" lexan, and colored the lens with appropriately colored markers. The stock lens film was just too dark to be able to see the lights at all, unless it was dark out. I also replaced the bulbs with LED's as my stock lens was deformed where it had started to melt from the heat.
gregp is offline   Reply With Quote
Old 06-02-2009, 11:32 AM   #4 (permalink)
Part # is T2502081
Thanks Slinky!
Just ordered this part from Triumph, I've also ordered some bright LEDs. Hopefully the thing will be more visible in sunlight.
Ian
Old 06-04-2009, 11:37 AM   #5 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
Ian,
I just did the LED thing, and it will be fine for you. I tried the LED high beam as well, but then switched it back to the old bulb, as it was too bright and distracting at night. Also, I started with white LEDs, but then took Mick's excellent advice and got greens for the turn signals, which are much more visible in the daylight. Just be careful when inserting the LEDs, as they have polarity, and will only light when inserted the correct direction. The sockets are also very delicate, so use care and some long needle nosed pliers or hemostats to get the reach you'll need. You'll love this upgrade!
ssevy is offline   Reply With Quote
Old 06-04-2009, 11:41 AM   #6 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
Didnt you just pull the rubber bulb holders fromt he bottom of the white plastic mount? its easy to change the bulbs then - no pliers etc.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 06-04-2009, 12:01 PM   #7 (permalink)
ssevy's Avatar
That method is way too easy, and would greatly reduce the opportunity to screw things up. I don't recommend it
Old 06-04-2009, 12:57 PM   #8 (permalink)
Hi chaps
I've done the LED replacements and all is good!
Also I replaced the "lens" (the black plastic thing with the indicator signs) with a new one I ordered from Triumph and its much better than the original one that came with the bike. It lets more light through so things are a LOT clearer in daylight.
Thanks for all your help
Ian
Instrument lights Readyt Hinckley Classic Triples 56 10-13-2010 03:37 PM
LED instrument lights MickMaguire Hinckley Classic Triples 23 05-15-2009 09:31 AM
Instrument lights gone tigerridermatt Tiger Workshop (archive) 4 02-21-2008 08:22 PM
instrument lights are out. EH97Sprint Sprint Forum 3 06-23-2007 10:38 PM
Red LED Instrument lights BigVinny Hinckley Classic Triples 0 03-30-2006 02:55 AM
