Hi,
The Sprint Dampers unit for the T309 Speed Triple is 160mm. They have accidentally supplied a 140mm before, as the one for the T509 Speed Triple is 140mm (reported on the T3 Sport / Touring Forum - they were very helpful and changed it straight away though).
Fyi, I have a T300 Sprint with a Toby steering damper, and this is 160mm also (and the same fitting).
With all the T300 models being similar, I am sure a 160mm would be correct for a TBS.
Hope this helps?
Geoff
