Fork Seals - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Honda Powersports Ontario TourismMotorcycle.comMotorcycle.com Classifieds!
Old 05-28-2009, 05:15 AM   #1 (permalink)
Fork Seals
Does anyone else have problems with forks seals going. I got mine replaced about 14k and now at 18 they seem to be gone again. Would that be down to a bad install job or the bumpy roads I am driving on. Any tips for when I get them doen again.
odowdn4 is offline   Reply With Quote
Old 05-28-2009, 08:11 AM   #2 (permalink)
Slinky's Avatar
Most likely down to a bad job, or using cheap seals. Another possibility would be too much fork oil used.
Or, it could be caused by pitted or bent fork tubes.
Old 05-28-2009, 09:31 PM   #3 (permalink)
Favourite Bike: My 98 TBS
Other Motorcycle: 83 Honda XL 250
I had the same scenario, pitted tubes was the culprit.
As for having them done, it's an easy job if you have a few hours to invest.
blackfly911 is offline   Reply With Quote
Old 05-29-2009, 01:13 AM   #4 (permalink)
Favourite Bike: 1996 Thunderbird
BRG-BIRD's Avatar
Other Motorcycle: 2000 Sprint ST
Also keep the bugs cleaned off your tubes as they can take out the seals.
"You are either on something or onto something"........The Common Man
BRG-BIRD is online now   Reply With Quote
Old 05-29-2009, 08:53 AM   #5 (permalink)
Thanks when you say pitted tubes do you mean the actual forks or something inside the forks. WHen you say easy enough do I need any speical tools. Also what oil recommended to go back in?
Old 05-29-2009, 02:01 PM   #6 (permalink)
Slinky's Avatar
Pitting occurs on the outside of the tubes, basically it means pits have appeared in the chrome. You would be able to see them by eye. That's not an easy fix, it either means new tubes or having your old ones hard chromed and reground.
I used 15w in mine, I think the book calls for 10w20
Old 05-30-2009, 09:12 PM   #7 (permalink)
Favourite Bike: 1998 TBS
I replaced the seals myself a while back, and it wasn't that bad. I was able to smooth out the pitted fork tubes with 2000 grit wet and dry paper. I posted a thread when I got done:
http://www.triumphrat.net/hinckley-c...ter-stand.html
Three years later my forks are still dry. I put on the fork protectors (black plastic shields that stick up above the seals to protect the front of the fork tubes), and I believe they have helped.
Good luck!
Most people generalize
http://www.worldwidewords.org/qa/qa-bob1.htm
bobsyouruncle is offline   Reply With Quote
Old 06-08-2009, 11:37 AM   #8 (permalink)
Favourite Bike: 99 Triumph Adventurer
meths389's Avatar
Other Motorcycle: Not enough cash or time!
Sorry to re hash this thread but I'm having a similar wear issue with my fork seals. I had them replaced back in March, genuine Triumph parts, since which time I've done 1700 miles. Now they're leaking again. The garage that did the work have agreed to do the work Free Of Charge... But they're asking for Fork Bushes(?) as well as the Seals.
Now I've replaced dust seals with oil seals on sports bikes, but never replacing the bushes too.
I still don't know why the oil seals failed as there's no pitting and the forks are straight. I'm wondering if the Triumph Gaiters are trapping moisture and road crap and therefore contributing to the very quick demise of my seals?
Any thoughts?
meths389 is offline   Reply With Quote
Old 06-08-2009, 02:10 PM   #9 (permalink)
Slinky's Avatar
Any thoughts?
With gaiters, the seals should last forever! My guess is that they were damaged when installed, or maybe overfilled.
Old 06-09-2009, 12:58 PM   #10 (permalink)
They were the genuine triumph seals so they should have been fine. I might try and do them myself this time. In relation to the oil what is recommended 15w or 10w ?
%$&* Fork seals blackfly911 Maintenance & Workshop Talk 3 08-22-2007 03:54 PM
Fork Seals SpeedBob Speed Triple Forum 10 01-19-2007 08:36 AM
Fork seals? Tailpipe Twins Technical Talk 2 08-14-2006 08:08 PM
Fork seals dazmo Hinckley Classic Triples 4 05-31-2006 03:35 PM
fork seals htown16 Classic, Vintage & Veteran 2 12-08-2005 03:29 PM
