Originally Posted by jdthaw
David,, for rear brake light switch... what make did you get? what part #???? I am assuming you did NOT use a triumph part?...is this correct???? what Exactly did you come up with???? please give complete details...i searched the forum and came up with a Napa # that did not appear correct when I saw the part...Thanx..JT
JT
I got mine from DennisKirk Part number 19-3939. I live close enough to drive there a couple times in the same day. It is not a Triumph part, they are just sold by thread size, not by specific manufacturer application. A universal fit. I also bought the boot part number 27-1523 to dress it up and connected it into the existing wiring. Very Simple.
However, according to Slinky you can get an automotive one. As long as you ask for one with the specifications I listed you should be good. You could also bring your broken one in to compare.
I hope this helps.
