Gel battery, HELP! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-28-2005, 02:33 AM   #1 (permalink)
Has anyone else notice how quickly the battery fluid dries out on the original Hinkley bikes?
Several solutions.
1. Re-locate battery to a cooler area (Why did they have to put it there in the first place?).
2. Install a heat shield. (Has anyone tried this?).
3. Use a gel type battery.
Can anyone tell me if a gel battery would be a straight forward swap for the original battery on a 92 Trident? Or does it require some electrical jiggery-pokery (now theres a good word for all you guys on the other side of the pond!).
Old 05-28-2005, 06:42 AM   #2 (permalink)
The main cause is linked to the fact than the alternator is doing a (too?) good job ....
Check that your regulator is working well, tension should not grow ovver 15 Volts at 5000 Rpm..
Think to add check water level monthly in summer time... And if your battrey is a litlle bit old and get hot, change it..
A well maintained Yuasa YB14LA2 last 3 years or more, you can get it for +- 30 €..
legend21 is offline   Reply With Quote
Old 05-28-2005, 11:33 AM   #3 (permalink)
jimmyj900's Avatar
It's largely because Triumph didn't use remote sensing on their voltage regulator.
It's a fixed-voltage regulator that maintains a constant voltage on the rotor -- regardless of system demands -- so it can't read the output to the battery and adjust accordingly.
If they'd spent another dollar it wouldn't be a problem.
Jim
Old 05-28-2005, 11:51 AM   #4 (permalink)
Jim
:razz: Unforutnatly Uk currency is £
Old 05-28-2005, 01:37 PM   #5 (permalink)
get a YTX14AHL-BS. Its a non maintenance battery and a straight drop in replacement for your old battery
[ This message was edited by: sq on 2005-05-28 16:27 ]
Old 05-28-2005, 01:51 PM   #6 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Has this changed with later models?
Bob
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Gel Battery ReserveBum Hinckley Classic Triples 8 07-09-2006 03:49 AM
Is the "Bonnie Battery AGM or Gel Cell? Stealthrider Twins Talk 3 08-19-2005 12:28 PM
Hey Jimmyj900- gel battery? TBAbob Hinckley Classic Triples 7 08-15-2005 10:43 PM
Gel battery. HELP Maintenance & Workshop Talk 4 06-10-2005 09:17 AM
You Gel -In? 04SpdTrpSE Speed Triple Forum 6 06-29-2004 05:44 PM
