Cams for Adventurer - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-24-2005, 08:18 AM   #1 (permalink)
tipere
This the first time I submit a question on your site.
I just bought a 1996 Adventurer. I adjusted the valves and noticed that the cams are of the green kind. Are they original on this model and if not what of plugs should I put in.
Thank you in advance
Michel
Old 05-24-2005, 09:36 AM   #2 (permalink)
Bonjour Michel
Did you note the ref N° stamped on your cams ???
Et si tu veux des infos en gaulois tu peux aller voir lÃ*..
Triumphadonf
On est une bonne bande un peu dingue :hammer:
[ This message was edited by: legend21 on 2005-05-24 07:39 ]
legend21 is offline   Reply With Quote
Old 05-24-2005, 10:30 AM   #3 (permalink)
Slinky's Avatar
Hi Michel,
Green cams are normal on an Adventurer.
Slinky is online now   Reply With Quote
Old 05-24-2005, 04:51 PM   #4 (permalink)
AKAIK the Tbirds got the blue cams and the speed triples and the higher performance bikes got the green cams.
2000 TBS Cafe Racer :: 2000 Frankenmille
TBSstunta is offline   Reply With Quote
Old 05-24-2005, 05:18 PM   #5 (permalink)
TbS stunta ; I think so too...
It 's why I asked Michel about ref N° to be sure ....
I Just poored a glass of Brouilly 2003 :-g , It is definitly better than Thunderbird :-x
Old 05-24-2005, 10:49 PM   #6 (permalink)
jimmyj900's Avatar
The "blue" swatch on the stock cams looks pretty green after some oil exposure so you need to compare profiles to be sure.
If the image below works then look at the end of your cams and compare the two to your cams. The blunt one is the "green" cam and the pointy one is the "blue" cam.
If the image doesn't work, e-mail me and I'll send you a copy.
Jim
Old 05-25-2005, 03:29 AM   #7 (permalink)
Slinky's Avatar
That explains it- I would have sworn mine was green
bc cams? ttbonnie Twins Technical Talk 2 09-02-2007 05:10 PM
tt cams big2332 Triumph SuperSports 5 03-09-2007 05:35 PM
Wilcox cams...red cams green cams...??? Johnjohn Hinckley Classic Triples 12 08-28-2006 09:27 AM
cams bob000 Triumph SuperSports 1 09-12-2005 04:45 PM
Cams for Adventurer tipere RAT - Canada 1 05-03-2005 03:41 PM
