Engine Kill, sidestand - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-23-2005, 07:53 AM   #1 (permalink)
Spooner's Avatar
D*** think stopped working....so yesterday after throwing a burger in my face at McDonalds I hop onto ma scoot and take off.....ofcourse the sidestand was still down. Luckily enough I was still in the parking lot when I heard the s***** of metal on asphalt.
Don't know if it's normal that these things stop working once in a while but it sure put a little scare in me....what if I had been doing a left in high speed...jeez.
:brk: Now, I know that it's a first to kick up the stand when getting on the bike...but hey, it just kinda slipped my mind ok!!
Now what?? Do I need a rocket science degree to fix it??? :???:
S.P.O.O.N.E.R.
Huh?
Speedy MattHilda & Thunderasaki
Spooner is offline   Reply With Quote
Old 05-23-2005, 08:00 AM   #2 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
It's a pretty easy fix. Chances are that the plunger is covered in dirt and a good clean will sort it out, but if not it's a case of undoing 2 bolts and unclipping the harness. These switches are comman to most models so you can often pick them up cheap on ebay.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 05-23-2005, 02:33 PM   #3 (permalink)
Favourite Bike: Whatever I'm riding....
Other Motorcycle: 07 Tiger ABS & 79 T140
Extra Motorcycle: 95 TB & 08 Ducati S4RS
Two years ago, I had the opposite problem; every time I put her in gear the engine would stop. The plunger on the sidestand switch which is depressed when the sidestand is down, wouldn't spring out when the sidestand went up.
I have to assume that, with your bike, despite the sidestand being down and the plunger being depressed, the circuit is not being made. Like Mick says, I think it's also a likely assumption that it's the same root cause - crud inside the switch.
I fixed mine by pulling the switch off, inverting it so the plunger was uppermost and then giving it a good squirt of switch cleaner whilst working the plunger.
[ This message was edited by: parrycm on 2005-05-23 12:35 ]
Chris
"Panniers can never hold everything you want, but they CAN hold everything you need."
parrycm is offline   Reply With Quote
Old 05-25-2005, 12:15 PM   #4 (permalink)
I had the same problem with the clutch safety switch. It was just gunk in where the little plunger is. They do get sticky after a while, especially if you ride a lot in nasty weather.
I put up with it all last season, and finally this Spring I replaced the little switch, and kept the old one as a spare (after cleaning!).
My Legend
LegendGirl is offline   Reply With Quote
To kill SAI or not to kill SAI, that is the question... 7589 Sprint Forum 11 12-09-2007 02:43 PM
Trying to Kill Me richleasure Twins Talk 9 10-28-2006 09:30 PM
How often do you use your engine kill switch? cully Hinckley Classic Triples 33 09-16-2006 03:31 PM
Help before i kill it ! CruiseControl Trophy 12 08-19-2005 10:06 AM
engine kill switch not working chadoll Triumph SuperSports 3 08-28-2004 12:45 PM
