Fuel Line Access - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-21-2005, 01:57 PM   #1 (permalink)
Favourite Bike: 03 TBird
Beemie's Avatar
Other Motorcycle: OIF Bonnie
Other than the side covers and the tank, what else needs to be removed to replace the fuel lines? It seems that the connection between the carbs is nowhere in sight.
Beemie is online now   Reply With Quote
Old 05-21-2005, 04:22 PM   #2 (permalink)
Slinky's Avatar
The lower connection is like a tee peice, and it swivels. If you pass the old fuel line down behind the carbs you should be able to pull it off, and push the new one one.
Be aware, there is a tiny filter pushed into the end of the tee.
Old 05-21-2005, 04:56 PM   #3 (permalink)
Beemie's Avatar
LIke I said, I don't see any part of the lower end.
Is it necessary to yank the air cleaner box?
Old 05-22-2005, 09:09 AM   #4 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
No, just use a flashlight and follow the old fuel line down between the carbs, it t's near the bottom. Look straight down from above, it sits just above the float bowls. You may need to move the vent hose out of the way to see it.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Old 05-22-2005, 10:09 PM   #5 (permalink)
Beemie's Avatar
Mick
If you have to peer down with a flashlight, how can it be possible to get a big mitt down there to service the line?
Fuel line size? Beemie Hinckley Classic Triples 8 05-06-2005 09:48 AM
Which fuel line goes where? Sprintguy Sprint Forum 1 02-21-2005 10:51 PM
Sprint ST Fuel Line Question (fuel tank to/from fuel rail) Sprint Forum 7 01-26-2005 10:23 AM
fuel line size cat Classic, Vintage & Veteran 3 04-26-2004 05:58 PM
Please help with Fuel Line msparks Sprint Forum 11 04-19-2004 03:29 PM
