mickey mouse engineering awards 2009........
Unless my swing arm is different to everyone elses, there IS no grease nipple for the swinging arm pivot bearings, at least not on the regular T'bird.
The two grease nipples shown in the shop manual are for the drag link bearings.
Believe me on this, my swinging arm is off the bike and on the bench at time of writing.
The pivot bearings have no means of being lubed other than pushing the centre bush out and dobbing grease in on the end of your finger.
And tonight's nomination's for the Michael Mouse Excellence in Engineering Awards are....
As a side issue, when I greased all the pivots, I always pumped until grease came out the ends of the bushes. SOP.
When I stripped the swing arm out, I found that the bearing at the bottom of the shock absorber was red with rust, totally munted.
You see, the wee hole on the pivot bush, which SHOULD allow the grease to travel from the centre of the pivot bolt, where the nipple is (are you following this...there is a test afterwards...) through to the bearing was blocked with clag.
So the grease that I saw coming out of the ends of the pivot was actually never getting to the bearing, it was just coming out of the centre bolt circumference.
Sad to say, the only way of finding out if this hole in the bush is blocked is to strip the b#gger.
NOW...........maybe that's why there is no grease nipples for the swing arm pivots.....to force you to strip and inspect the whole damn thing every few years!
The parts for the bearing repair were not expensive (<£30) but the whole situation stalled the bigger project of the weekend, namely replacing the 3cyl motor with a 1200. Pending!
