According to the guys at British Customs, Triumph discontinued the Thunderbird Low Bar kit and they are no longer available. You might find a set somewhere if you look around long enough. I ended up going with a set of stock Speed Triple bars and they worked out pretty well once I drilled the holes in the correct locations.
