Speedometer Question - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda PowersportsSportbikeTrackGearMotorcycle.com
Old 04-08-2009, 02:01 AM   #1 (permalink)
Bought a 98 TBS a couple of wweks ago. I removed the speedometer and was wondering if you need to lube or grease the connection between the cable and the speedometer. If so what is the best lubricant. Thanks
mynock03 is offline   Reply With Quote
Old 04-08-2009, 03:52 AM   #2 (permalink)
Slinky's Avatar
The only thing you have to lube is the inner cable, this should be lubed with high melting point grease. It is best to avoid lubing the top 5-6" of the cable.
Old 02-04-2010, 12:15 PM   #3 (permalink)
Favourite Bike: British Green 99 Legend
Legend JJ's Avatar
Other Motorcycle: Jet Black 09 Speed Triple
so you don't have to lubricate anything inside the speedometer? i finally got a used assembly from a 96 Tbird with 68k on the clock. everything appears to be in working order, i'm just curious if any gearing inside could use a shot of high-temp grease or graphite
Legend JJ is offline   Reply With Quote
Old 02-04-2010, 01:47 PM   #4 (permalink)
Slinky's Avatar
No, I don't think there is anything to be gained by lubricating inside the head. The gears and tumblers etc are plastic and grease combined with dust will just clog them up.
There is probably an oil filled damper inside the head, to damp out needle fluctuations, but that is sealed and needs no maintenance.
I should have said in the earlier post that the speedo drive should also be greased, that normally gets done at tyre change time.
'03 Speedometer and/or other question? Retom7 Speed Triple Forum 17 03-19-2009 08:23 PM
Speedometer question KD5QOQ Hinckley Classic Triples 1 01-21-2009 08:57 PM
Speedometer Question Blacklion50 Twins Technical Talk 8 06-08-2007 08:54 PM
Question: Triple speedometer Speed Triple Forum 1 12-09-2004 05:59 PM
HID lights & speedometer question... Texas-Hooligan Speed Triple Forum 2 05-19-2004 01:13 AM
