Ancilliary Lights for '97 Tbird - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Old 04-04-2009, 06:28 PM   #1 (permalink)
R0B
Favourite Bike: '95 TBS special
Other Motorcycle: '99 Tbird being built
Extra Motorcycle: '97 sprint sport
Hi All, I've just bought a '97 Tbird. I drove it home in the dark, and realised that the standard headlight is useless..............seems too diffused and too dim. Has anyone mounted extra lights (maybe dare I sat it Harley style) on their bikes?. Pictures would be great.
Thanks
Rob
R0B is offline   Reply With Quote
Old 04-07-2009, 12:23 AM   #2 (permalink)
How about brighter filiment? Anyone have recommendations on those? I'm interested in a brighter light for safety reasons.
ericp is offline   Reply With Quote
Old 04-07-2009, 02:45 AM   #3 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Silverstars work pretty nice.
If you can get your hands on some european ones they are better, but technically not legal in the US (too bright).
Cheers,Denny
denny is offline   Reply With Quote
Old 04-08-2009, 08:48 AM   #4 (permalink)
Other Motorcycle: adventurer
Extra Motorcycle: tiger 900
Headlamp
Land rover accessory headlamps about £20 a pair clear lense a bit more and ring 130/90w lamp available from motor factors should cure the problem, mine is now like a search light but consider wiring in a relay or two like tigers or sprints so as to not overload wiring and switchgear.
metalguru is offline   Reply With Quote
Old 04-08-2009, 09:09 AM   #5 (permalink)
R0B
Do you have any pictures of them mounted, and details of the brackets/fittings you used?
Thanks
Rob
Old 04-08-2009, 09:18 AM   #6 (permalink)
Land rover use 7" lamps so a straight swap and they take H4 halogen.
Old 04-08-2009, 11:17 AM   #7 (permalink)
R0B
Right, sorry I get you now (being extra thick today). You mean the landi headlamp is a like for like replacement for the Triumph one, not add on accessory lights. That's very interesting. Any particular model/year?.
Thanks
Rob
Old 04-08-2009, 11:41 AM   #8 (permalink)
Hi Rob
Yes they are like for like and should just swap. As all landi's are 7" any year will do...4x4 mags will show lots of dealers but be careful of rip offs. I believe demon tweaks do the big h4 lamps ie 130/90w.
Wiil try to get the brain to remember where I have got them from. I have found running the large wattage lamp that the reflector does discolour with age and use so buying a pair is a good one. I ride everyday with lamps on and got about 3 yrs i think from reflector before it showed signs of distress.
Regards
Nige
Old 04-08-2009, 01:11 PM   #9 (permalink)
Favourite Bike: 02 Thunderbird
So, this bit about adding in some relays if moving up to a LR lamp - in what ways are they protective, to which circuit should they be connected?
I understand relays to be connected to two circuits, typically; the one which activates the relay, and the one which is closed (or opened) upon relay activation.
shoggot is offline   Reply With Quote
Old 04-08-2009, 01:28 PM   #10 (permalink)
Favourite Bike: Well, Duh!
MickMaguire's Avatar
its largely because the beam pattern is poor. Get yourself a single 7" Cibie unit and you will notice a world of difference.
Mick...
Just remember; an awful lot of the free advice you will get on forums is worth exactly what you paid for it. There will always be somebody trying to convince you to do something really stupid, just because they did it or want to do it.
Tail lights out - Brake lights work crescen7 Daytona Deliberations 7 09-02-2008 10:00 AM
Fog lights for a Tbird? chrisshaeffer Hinckley Classic Triples 15 11-28-2006 11:38 AM
tbird sport carb rubbers for tbird & legend Spooner Hinckley Classic Triples 14 08-11-2005 02:45 AM
98-99 TBird Sport Questions- trans,tires,lights redtbird Hinckley Classic Triples 0 11-15-2004 10:17 PM
TBird: Are the turn signals also running lights? Hinckley Classic Triples 6 05-25-2004 12:09 AM
