ignition sensor screw
Can someone tell me what size of hex socket driver I need to remove the hex 'screw' that holds the ignition sensor in place ? The screw in question is listed on bikebandit.com as
SCREW,SHLD,SKT,M6X1.0X15,S/S M6 X 12MM PN 5576239-001
and is for a 1996 Adventurer (lower serial number)
I can't seem to get a good solid hold of it with anything in the 6, 7, or 8mm hex socket range, and its starting to round off.
Reason: updates
