Thunderbird Oil Level - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!Honda PowersportsNew BonnevilleOntario Tourism
Old 04-02-2009, 04:07 PM   #1 (permalink)
I've read a number of threads on the forum regarding not overfilling the thunderbird.
With my 2003 tbird on the centre stand and on level ground the oil level is nearly at the top of the inspection window, rather than midway as is stated in the manual. The level is about 2mm below the top of the glass inspection window.
It's clearly above the standard inspection level, but would that be considered as over fill and should I take some out.
Any views/thoughts?
Thanks
T'Bird2003 is offline   Reply With Quote
Old 04-02-2009, 04:23 PM   #2 (permalink)
Favourite Bike: T'bird/Trophy hybrid
Other Motorcycle: Toad King
Extra Motorcycle: XS650 Yam
oil fill level
I have never paid much heed to the 'don't overfill' warnings.
Every time I do an oil change, I always put 4 litres into the bike, it always comes up to the top of the sight glass, and runs fine.
I have covered 43000 miles pulling a sidecar around after me with no mechanical troubles at all. So far!
2 wheels good 3 better is offline   Reply With Quote
Old 04-02-2009, 04:43 PM   #3 (permalink)
The niggle is that I took care in doing it all. I drained the old oil overnight and put 3.5 litres in and ran the engine for about 5 minutes to get the oil pumped round. I then let it settle for a bit before doing the final top up. It took another 0.3 litres, so 3.8 litres in total. I guess it took longer for the oil to get into the sump than I expected.
It would be interesting to know what quantity of oil is required to raise the level from the bottom to the top of the inspection window.
Old 04-02-2009, 04:49 PM   #4 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Both wheels are supposed to be sitting on the ground when you check the oil level at the sight glass. Since the back of the bike is higher than the front when on the centerstand. Maybe have a friend hold the bike level while you look in the sight glass. It might be closer than you think.
Cheers,Denny
denny is online now   Reply With Quote
Old 04-02-2009, 05:03 PM   #5 (permalink)
level
One thing I forgot to say was that I have noticed that parking the bike on the tiniest slope throws the apparent oil level out wildly.
I have never actually put my bike into the garage to see what the level is like on a nice flat floor!
Too busy riding the old dog.
Old 04-02-2009, 05:05 PM   #6 (permalink)
Good point Denny. I will check it out.
Old 04-02-2009, 05:58 PM   #7 (permalink)
Favourite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast
i use a handheld mirror , actually my wifes , while sitting on the bike upright .
hth , Woody
Woody1911a1 is offline   Reply With Quote
Old 04-02-2009, 08:03 PM   #8 (permalink)
Favourite Bike: 03 Tbird
Oil Level
I too have an 03 tbird with a center stand. I found by trial and error that if you raise up the front wheel using a regulation hockey puck (which is 1" thick) the bike is level. Then the oil should be half way up the sight glass.
By the way. A hockey puck has one other use. I keep it in the saddlebag and use it flat under my sidestand when the ground or asphalt is soft.
Try it you will like it.
Blackhead is offline   Reply With Quote
Old 04-03-2009, 01:58 AM   #9 (permalink)
Favourite Bike: 2002 Thunderbird
Other Motorcycle: 1973 Norton Commando
Pucker up
If you're into avoiding hernias, you can ride the rear wheel on the puck before hoisting it on the center stand. That extra inch makes getting her up a whole bunch easier.
Vertigo1 is offline   Reply With Quote
Old 04-03-2009, 02:04 AM   #10 (permalink)
Administrator
Legend
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
I drain 4 litres out and put 4 litres in, the oil level is always slightly over-full, 75,000km on the clock.
Ride on !
Tbirdnz is online now   Reply With Quote
need some basic info on the Thunderbird/Thunderbird Sport ohiorider Hinckley Classic Triples 23 12-06-2010 12:49 PM
will a thunderbird tank fit a thunderbird sport? aeycue Hinckley Classic Triples 15 10-23-2009 06:42 PM
Oil Level Byker T3 Sport / Touring Forum 2 09-22-2008 02:15 PM
Oil Level neale Twins Technical Talk 1 09-09-2006 09:42 AM
Float level / Fuel Level for 1998 Trophy 900? CharlestonRider Trophy 8 06-04-2005 05:07 PM
