03-30-2009, 01:09 PM
Production 125 Favourite Bike: 65 bonnie,98 trident
trident 900 blown fuse
Has anybody any ideas for my problem!!. Left my Bike on Friday tucked up under its cover,Went to start it this morning and it blew its main fuse. the alarm is a data tag and is ok. the starter motor turns of when shorted. the looms look ok. any ideas before I strip the thing down!!
03-30-2009, 01:12 PM
Site Supporter Pole Position Favourite Bike: 1996 Thunderbird "Nessie"
Posts: 3,563 Other Motorcycle: 1973 Trump TR7RV "Loosie" Extra Motorcycle: 1968 BS 350 GTR "Smokie"
Are you talking about the in-line fuse, or the main in the fuse box?
I blew the inline once - couldn't find the culprit. Sleeved the main loom, and no probs since....
03-30-2009, 01:15 PM
its the 30 amp fuse in the main fuse box
03-30-2009, 01:45 PM
Site Supporter Moto Grand Prix Favourite Bike: '99 ThunderLegendSprint
Posts: 3,110 Other Motorcycle: Wouldn't mind a Tiger 800 Extra Motorcycle: Can't ride more'n one...
did it blow switching ignition on or when pressing starter ? Do you have a wiring diagram ? (If not, PM me & I'll scan one for you. Tell me year of the bike.)
Mike
(From M/cr originally)
Legend chassis, Tbird tank/seat, Sprint fairing, tubeless wheels, Thunderbike 3-1, air box mods, 115/40 jets, DJ needles, Ignitech with TPS, ZX6R shock, ZX7R USD forks/yokes, Alcon 6 pot
03-30-2009, 07:28 PM
as soon as the ignition is switched on.
03-30-2009, 07:31 PM
I have the haynes manual for the bike.
03-30-2009, 07:46 PM
Ok, so with the Haynes diag on page 9.24, the white wire coming off the ignition switch is #1 suspect for a short to ground. Follow that wire around & see what you can find. 1st unplugging the alternator plug (connector with brown & white heavier gauge pair) can eliminate (or otherwise) a fault inside the alternator.
03-31-2009, 04:29 PM
OK cheers, that's a job for the weekend!! I will let you know how I go on. I don't want to put the old girl down just yet. (80,000 miles plus). thanks.
04-03-2009, 11:30 AM
found the fault chaps, the alternator regulator is blown!!! will need to check the wiring still just to be on the safe side!!!!
04-05-2009, 04:52 PM
the horn was also shorting out !!!. . must be when some arse tried to nick the bike !!!.
