01-24-2009, 12:25 PM
valve job on a legend
I'm afraid I'm in the need for a valve job on my 1999 Legend. OEM parts alone (BikeBandit) look like about $1200.00. Does anyone out there know of a cheaper way to go about this?
01-24-2009, 10:13 PM
Formula Extreme Favourite Bike: 2003 Speed Triple
Posts: 728 Other Motorcycle: 1999 Legend
Huh?
do you need to replace your valves or just check the clearances?
No quarter asked, none given
01-24-2009, 10:32 PM
SuperSport Favourite Bike: 2000 Adventurer
Posts: 1,038 Other Motorcycle: 67 T100C Extra Motorcycle: Buell Blast
why do you think this ?
01-25-2009, 12:36 AM
Site Supporter Moto Grand Prix Favourite Bike: '98 Thunderbird Sport
Posts: 2,585 Other Motorcycle: '06 Husqvarna TE 610 Extra Motorcycle: '95 TBird - Project
I've heard the term "Valve Job" used when it should be described as Valve Clearance Adjustment. Years ago valve job always meant new valve guides, grind/replace the valve seats, new valves where needed, and new springs and keepers.
I am not sure how much a dealer charges for valve clearance adjustment, but it is very straight forward if you have some mechanical acumen.
Did a service department somewhere tell you you needed a valve job? Maybe they meant Valve Clearance Adjustment?
Give us a little more detail and someone will be able to help more. If the bike has more than 15K miles or so and the valve clearances have never been checked/adjusted it is possible that you have one or more burnt valve seats and then a valve job could be necessary.
Triumph maintenance schedule for Valve adjustment was originally every 6K miles. But later in the production run they modified that to 6K then every 12K after the initial check..
Cheers,Denny
01-26-2009, 10:34 AM
The parts are in fact expensive.
I hope you don't really need a valve job since the labor will be high also.
I don't think anyone like Kibblewhite makes aftermarket valves for our bikes.
In the old days valves could be renewed by cutting the seats and relapping (if they weren't that bad) but the new four stroke technology doesn't allow for that anymore.
Good luck and keep us posted.
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
01-26-2009, 01:48 PM
Kibblewhite does in fact make valves for our bikes. Not sure how the pricing will compare.
http://www.blackdiamondvalves.com/default.htm
Jimbo
Kroger Plus Member
05YZ450F
89 CR500
01-26-2009, 02:20 PM
Thanks for the feedback -This bike has 50K+ miles on the clock. I did the valve clearance adjustment thing + some new shims on the intake valves about 3 mths ago. That took care of the problem ( only ran on 2 clyinders until engine got hot then 3rd cylinder kicked in & ran fine) but Now it's started doing the exact same thing again. That's what makes me think that the entire valve train needs to be dealt with.
01-26-2009, 02:48 PM
I would check the clearances again to make sure that it is/was valve related.
Jimbo
Kroger Plus Member
05YZ450F
89 CR500
01-27-2009, 12:16 AM
Compression check.
Cheers,Denny
01-27-2009, 06:30 AM
Doh! Why didn't I think of that?!
Jimbo
Kroger Plus Member
05YZ450F
89 CR500
