Thunderbird Rear Wheel change 16" -to 17"?
I have been checking out the tyres available for my thunderbird 2002 model which has a 150/80/16 rear wheel fitted as standard and found that this is a very limited size as far as choices of tyres, there is a lot more to choose from in 17" size, has anyone change to 17" and will the Thunderbird Ledgend or Sport wheel which I believe to be 17" fit on or should I just stick with the standard rim size. If so what would you blokes recommend in the way of tyres, I have the standard Pirelli Dragons on at the moment.
Cheers,
Rick.
