01-21-2009, 11:50 AM
Powerbike Favourite Bike: 01 Legend TT
Posts: 360 Other Motorcycle: '74 Yamaha TX500A Extra Motorcycle: 1965 Honda Sport 50
Aux Lighting for Legend?
Any ideas for an extra couple of lights on the front of the 2001 Legend? Suggestions?
It's not what you look like when you're doin' what you're doin', It's what you're doin' when you're doin' what you look like you're doin.
from 1970 song "Express Yourself" by Charles Wright and the Watts 103rd Street Rhythm band.
01-21-2009, 09:06 PM
Supersport 600 Favourite Bike: moto guzzi sp1000
Posts: 188 Other Motorcycle: triumph legend TT Extra Motorcycle: KX80
There are ways to turn the front turn signals into running lights as well as turn signals; you'll have to search the threads for the process.
I made mounts attached to the radiator. I wouldn't try this without a crash bar or something to stop the mount from destroying the radiator in a tipover. You may recognize these as old school harley turn signals pressed into triumph duty.
01-22-2009, 08:33 AM
Moto Grand Prix Favourite Bike: '99 Legend / '98 TBS
I like Toller's mounting idea.
Walmart sells small, round, chrome driving lights for around $20 a set. That's the way I'm leaning.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
01-22-2009, 12:11 PM
Where would be the best point to get the 12V ? In light housing behind headlight? Will it accept 2x55Watts?
01-22-2009, 12:30 PM
2X55 watts = 110
110 watts @ 12 volts = 9.1 amps
So the answer is probably going to be running a dedicated line with fuse for the added lighting. You may want to add a relay to control the light along with the existing lighting or add a switch to operate them independently.
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
01-23-2009, 03:02 PM
Site Supporter Moto Grand Prix Favourite Bike: '99 ThunderLegendSprint
Posts: 3,110 Other Motorcycle: Wouldn't mind a Tiger 800 Extra Motorcycle: Can't ride more'n one...
Definitely use a separate line/relay/fuse. Don't add that to what's already running thru' the Ignition Switch. The likely effect of which would actually be to increase the alternator output voltage even higher. This is because the alternator regulator senses after the loom volt drops of ignition etc. This is why the battery already gets around 15V (Not a more usual 14.5) & needs periodic topping up.
There is a spare 'Ignition On' output from the switch on a small gauge wire (yellow IIRC) which goes as far as the loom connector in the headlight shell. This is a handy Ign + feed which can be used to power relays (coils only, take main power from Battery term.) for all sorts of auxiliary electrics which need disabling when ignition is off. (Heated grips in my case.)
I'd be tempted to have single filaments each side, wiring one with 'dip' the other 'main'.
Legend chassis, Tbird tank/seat, Sprint fairing, tubeless wheels, Thunderbike 3-1, air box mods, 115/40 jets, DJ needles, Ignitech with TPS, ZX6R shock, ZX7R USD forks/yokes, Alcon 6 pot
01-24-2009, 03:42 PM
A few thoughts:
12 gauge or even 10 gauge stranded wire and good connections for the power going to the lights. This wiring can go directly to the battery with an inline fuse AND A GOOD GROUND .
Run the relay off of a switched power supply. Relays do not need much power and will operate just fine with 22-18 gauge.
MORE LIGHT EQUALS GOOD
