Speedometer question
I recently lubed the speedometer cable with cable lube and now (about two weeks later) it locked up. It probably broke at the wheel end because at the speedo end I can't turn the square drive very much at all and it doesn't turn when the bike is moving. I pulled the cable off the speedo and ran it down the street to verify that it's not turning.
Did I mess up by lubing it in the first place? I remember some teflon lined control cables years ago that you were not supposed to lube or you would damage them.
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
