TBS Intake and Exhaust Mod. - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com Classifieds!Motorcycle.comNew Bonneville
Old 01-20-2009, 10:22 PM   #1 (permalink)
Favourite Bike: 01 Sprint ST Turbo
tommyturbo2's Avatar
Other Motorcycle: 98 TBS
Extra Motorcycle: Suzuki DR400E dirt bike
I recently posted plans to modify the carbs and exhaust on my 98 TBS. Here's what I've done so far:
Emgo reverse cone megaphones (repacked with FMF 4 stroke packing), carbs modified up to 145 main jets, with TBS needles and 3 shims, Back of the front airbox removed leaving the lateral aspects of the airbox to hold the black plastic sidecovers on, and a single standard K&N filter in the stock airbox location. This set up allows me to retain the crankase vent system into the airbox, plus keep the airbox drain port on the left rear of the airbox. The results has been excellent with no flat spots in acceleration, and it will now hit the rev limiter in all 6 gears. Full throttle in first will slightly lift the front wheel off the ground at about 6000 rpm. MPG has actually improved from 40 to 44 on 87 octane fuel. Has anybody else done this? Has anyone drilled the slide ports out to improve quickness of throttle response? Thanks, tommyturbo2
TTG..Two Triumph Garage
tommyturbo2 is offline   Reply With Quote
Old 01-23-2009, 11:12 PM   #2 (permalink)
Favourite Bike: 2002 Thunderbird 900
Originally Posted by tommyturbo2 View Post
I recently posted plans to modify ....Back of the front airbox removed leaving the lateral aspects of the airbox to hold the black plastic sidecovers on, and a single standard K&N filter in the stock airbox location. This set up allows me to retain the crankase vent system into the airbox, plus keep the airbox drain port on the left rear of the airbox. .....
Pictures?
RickN is offline   Reply With Quote
Old 01-25-2009, 09:26 PM   #3 (permalink)
TBS airbox/exhaust mods, pics
As of yet, I have no photos of the airbox/exhaust mods, but I will take some and post them. I had to increase the size of the main jets to 150's, and remove 3 of the 6 shims from the main needles to cure a slight cruising surge that was occuring between 65 to 90 mph. I have posted some pics of the bike on my (tommyturbo2) gallery. tt2
Want to buy a 790 intake cam Blacklion50 Twins Technical Talk 1 09-27-2007 09:13 AM
intake and exhaust valve settings for 78 T140V 750Bonnie Classic, Vintage & Veteran 2 08-30-2006 05:30 AM
WTB; 790 Bonney intake and exhaust cams. agro Twins Talk 1 12-20-2005 04:10 PM
WTB; 790 Bonney intake and exhaust cams. agro Club Cafe' 0 12-20-2005 09:43 AM
Dealer recommends re-Jetting without improving intake or exhaust? 00wabbit Hinckley Classic Triples 4 01-20-2005 08:22 AM
