Problem removing Adventurer tank badges - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGear
Old 01-20-2009, 07:14 AM   #1 (permalink)
Unhappy Problem removing Adventurer tank badges
I want to paint my tank and started to remove parts off it. No problems with knee pads (I was surprised they are still here- it was so easy), then broke head of one bolt keeping tank badge (that's my problem), then removed both bolts on other side to see construction. After both bolts are removed I can't remove badge and rubber under it! No bolts needed But what is the trick? Is it glued (better than knee pads) or rubber stick to metal so good in 10 years?
SARUNAS is offline   Reply With Quote
For those that are thinking about removing badges netvampire Twins Technical Talk 2 12-08-2008 08:03 PM
Looking for those tank badges karlitoway Classic, Vintage & Veteran 7 11-02-2008 03:16 PM
Where can I get some tank badges in the U.S.? Tenover Twins Talk 11 02-22-2008 09:28 AM
Tank Badges rbrian_taylor Club Cafe' 2 01-31-2007 07:06 PM
"68" Tank badges on the TBA tba-golfer Twins Talk 17 08-03-2006 11:24 PM
