An engine loud knocking
My T-Bird started to have some issue a couple days ago. I was riding by freeway about 15 minutes and engine suddenly tried to cut out. But I accelerated the motorcycle and take exit. When RPM was about 2.000-3.000 RPM I heard a really loud engine knocking. I stopped and still heard the knocking. I switched off the engine. After 10 minutes I run engine again. Everything worked without knocking but I started to hear kinda valve noise. When I opened throttle a couple of times the knocking came back. It was reproducible from 2.000 till 3.000 RPM. But it was really load knocking. I left motorcycle on parking spot. I returned back next day to move motorcycle to dealership and checked it again. I have just heard valve noise. The Dealership car has picked up motorcycle and has left.
Next day I called to dealership to see how is going. The guys told me, everything works good except valve noise. When I checked motorcycle in dealership and tried accelerating my motorcycle and it was stalling near 2500 rpm. But over 3.000 rpm everything worked good. I don’t know what the reason of this issue.
Right now motorcycle on dealership to clean and sync carbs.
The millage: 35.000 miles. The last valve adj and carb sync was 3.000 miles ago. It looks like pilot jet cause the issue, but what was the loud knocking and valve noise.
AlgorNick
