Rear sets on an Adventurer? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-19-2009, 11:29 AM   #1 (permalink)
KD5QOQ's Avatar
Will the brackets, linkage, pedals, etc. fit on an adventurer?
Has anyone here tried it?
Jimbo
Kroger Plus Member
99 Adventurer(cafe'd), 06 SV1000S
05YZ450F
89 CR500
KD5QOQ is offline   Reply With Quote
Old 01-19-2009, 12:32 PM   #2 (permalink)
Favourite Bike: 1996 Triumph Adventurer
Other Motorcycle: 2000 Yamaha RS Venture
Extra Motorcycle: 2001 Kawasaki Nomad FI
What brackets, linkage, pedals, etc? What parts and/or application are you talking about?
Mag00
Mag00 is offline   Reply With Quote
Old 01-19-2009, 05:09 PM   #3 (permalink)
Favourite Bike: '99 ThunderLegendSprint
IrlMike's Avatar
Other Motorcycle: Wouldn't mind a Tiger 800
Extra Motorcycle: Can't ride more'n one...
I've just fitted TBS (rearset) footrests on my Legend. I'm somewhat short-legged but I'm very happy with the results. (Should mention here my seat is a Tbird item.) Legs & knees can now be used for better control on cornering & bumpy roads rather than just being dead weights. (Stock is fine if you like more 'forward'/'cruiser' controls, just not so useful for shifting weight to aid control.)
I was also lucky that after reversing the gear shaft lever 180 degrees to maintain stock up-for-up shift sequence, I still had 4 or 5mm clearance above the sidestand. Wasn't totally sure I'd be able to do this before I bought the rests/levers. For some reason (wear?) my buddy's TBS sidestand seems to fold up 10mm higher/closer than the Legend.
The TBS rear brake lever pivots on the footrest mount & is way shorter than the stock item & hence way less 'mechanical advantage' (leverage).
It's noticeably more work to apply the rear brake when used alone at <10mph but I'm also less likely to lock it up in a more panicky emergency stop situation. Overall I'm happy with that. (BTW, I checked to see if TBS used a different master cylinder - it doesn't, same part#)
Legend chassis, Tbird tank/seat, Sprint fairing, tubeless wheels, Thunderbike 3-1, air box mods, 115/40 jets, DJ needles, Ignitech with TPS, ZX6R shock, ZX7R USD forks/yokes, Alcon 6 pot
IrlMike is online now   Reply With Quote
Old 01-20-2009, 12:08 AM   #4 (permalink)
Well, now I know what "rearset" means.
Mag00
Old 01-20-2009, 06:41 AM   #5 (permalink)
KD5QOQ's Avatar
Thank you Mike! And yes, I should have been more specific about the TBS controls.
Jimbo
Kroger Plus Member
05YZ450F
89 CR500
Rear Sets JamesLKY Twins Technical Talk 10 09-05-2008 12:31 PM
LSL Rear sets bodpbucho Twins Technical Talk 9 04-05-2007 04:48 PM
Rear sets ds6380 Speed Triple Forum 0 05-19-2006 03:31 PM
Rear Sets Hinckley Classic Triples 13 04-18-2005 12:30 PM
Rear sets blkse04 Daytona Deliberations 3 03-10-2005 02:02 PM
