The replacement caliper's pucks may not be moving freely enough.
Or perhaps the caliper is not fully centered. To figure that out, remove the pads, then move the caliper to one face bears against the rotor, then the other. The mounts should be right smack dab in the middle. Otherwise shim them.
Are the new pads wearing evenly? if they are wearing on one portion of either pad more than another, the caliper is slightly askew.
Do the brakes pulse when lightly applied (when moving) The rotor could be dinged, or if you removed it, there could be some grit preventing perfect allignment. I supose the same could be true if there is something interfering with the caliper being fully seated against the mount.
Try putting it on a centerstand or someother stand; have a friend gently apply the brakes with you watching from the rear. If the rotor or caliper deflects, either a puck is sticking or the caliper is out of allignment. YOu may have to be touching the caliper and the rotor to feel the deflection.
I dunno. Keep us posted if you figure anything out.
