Adventurer Rear Light Fitting
Even Harley Davidson got it better than Triumph on their 'Bob' tails! This really is a pathetic piece of engineering and has caused untold grief all over the Planet.
My solution was to remove the lense cover and bulb holder. It will be seen, the original stupid design, that two small nuts protrude through from the rear. The small surface area these two nuts (and washers) provide is all that secures the whole assembly to the guard. The threads the two nuts fit onto are part of the rubber mounts.
Whats needed is to enlarge the contact area of the two nuts to prevent the plastic from breaking due to vibration. It will be seen that a ridge is moulded into the plastic to allow for the wires for the lamps to be grommeted through the rear. Drill two similar size holes, one on either side of the 'ridge'. Make up a piece of flat metal, I used aluminium, and drill so that the two holes on each side line up. Fit the cover and drill two more holes through the metal bracket that supports the lamp. Fit two new bolts through from the back placing a measured length of small diameter rubber hose over each to act a 'shock absorbers'. Place pre drilled metal flats over the bolts, spring washers and then the four nuts.
A bit long winded, but have had no problems for 30,000 miles, and not expecting any!
