A side stand for my Legend - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comNew BonnevilleOntario TourismSportbikeTrackGear
Old 01-18-2009, 09:47 AM   #1 (permalink)
Hi everybody from Italy,
My Legend was heightened but the side stand is stock lenght. When stopped and on the side-stand, the bike is too down. Sometimes it seems ready to fall. So i need to mount a longer side stand. I don't want to modify the original one. Do you know if i can use a (longer) side stand coming from another Triumph model? Or from another motorcycle in general?
Many thanks and greetings from Italy to all of you.. "Triumphant" guys
Gianluca.
GianlukeITALY is offline   Reply With Quote
Old 01-18-2009, 11:08 AM   #2 (permalink)
Favourite Bike: '99 Legend / '98 TBS
BigAl8295's Avatar
The T-Bird sits higher than the stock Legend, so the sidestand should be taller. I'd go that direction instead of trying to modify the stock one.
In the mean time, you could carry a block of wood to put under the sidestand.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 01-18-2009, 12:59 PM   #3 (permalink)
Thanks BigAl... Very kind So..could someone be so kind to take exact measures of his TSport side stand? Maybe it's less curved or longer than Legend's one..Who knows? In case i will buy it to replace the stock and shorter one.
Thank you,
Gianluca.
P.S.: Sorry for my poor english
Old 01-18-2009, 10:10 PM   #4 (permalink)
Favourite Bike: Legend-01
Other Motorcycle: Honda NTV 650 Revere
sidestand
http://www.bike-teile.de/index.php?s...&teilid=545383
Proffa66 is offline   Reply With Quote
Old 01-19-2009, 01:23 AM   #5 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
The TBird stand it longer than Legend Stand.
TBird Sport Stand is longer and more straight than TBird stand.
So you have two options that possibly will work for you.
Thank you,
Gianluca.
Cheers,Denny
denny is offline   Reply With Quote
Old 01-19-2009, 08:42 AM   #6 (permalink)
Favourite Bike: 01 Legend
Was in that same boat
When I put the ZX/7 shock on the back it got taller enough that every use of the sidestand was scary. I'd keep running back to her thinking she was going over and my wife was just positive it was falling.
I solved it by using sidestand from a regular T-Bird which put it into the correct upright attitude. After that I added the centerstand which I prefer to use anyway. Old habit from a Guzzi SP-1000 (Toller do you have that fear with your SP?).
At any rate T-bird should work unless it's really tall.
Most famous last words: "Hey ya'll watch this"!
jenglandtoyman is offline   Reply With Quote
Old 01-19-2009, 10:19 AM   #7 (permalink)
Thanks guys,
So i have to look for a Thunderbird or Thunderbird Sport side stand... Even if TSport stand is the longest side stand available for our classics..Isn't it? Longer than Thunderbird side stand..Is it correct?
Proffa66 thank you for your kind link but it is a side stand for a normal Thunderbird and not for a Thunderbird Sport, is it right?
Jenglandtoyman how much is your Legend taller with ZX/7 shock?
Thanks again to all of you guys,
Gianluca.
Old 01-19-2009, 01:31 PM   #8 (permalink)
Yes, that link is for normal TBird, (-95)
Search for cheap suspension upgrade and it tells you more. ZX7 is same as ZXR750 in Europe http://homepage.ntlworld.com/webzxr/...y/History.html Accordin that page, there is slight different in between -91-92 to -93-95 models shock.
Old 01-19-2009, 03:00 PM   #9 (permalink)
Thanks guys,
I can't tell you because I did not measure at the time but my guess would be seat height increased between one and two inches. I would guess angle of sidestand was changed by adding around an inch but I would be just doing that from memory.
Old 01-19-2009, 05:41 PM   #10 (permalink)
Favourite Bike: '99 ThunderLegendSprint
IrlMike's Avatar
Other Motorcycle: Wouldn't mind a Tiger 800
Extra Motorcycle: Can't ride more'n one...
I'd suggest you try a standard Thunderbird stand. The stock Legend rear wheel diameter with a 160/60x17 tyre is less than both Tbird & Tbird Sport. Remember that if the bike is too vertical when on the sidestand it will too easily roll off & fall over when the road's a bit inclined.
Legend chassis, Tbird tank/seat, Sprint fairing, tubeless wheels, Thunderbike 3-1, air box mods, 115/40 jets, DJ needles, Ignitech with TPS, ZX6R shock, ZX7R USD forks/yokes, Alcon 6 pot
IrlMike is offline   Reply With Quote
Center stand and side stand nfldrunner Hinckley Classic Triples 23 01-25-2010 12:50 PM
Side Stand or Centre Stand??? dryheat Twins Technical Talk 14 08-12-2008 06:47 PM
Chain adjustment-center stand or side stand? andyc740 Trophy 7 04-02-2008 06:41 PM
shorter side stand (kick stand) ? TriumphTT_2 Triumph SuperSports 6 06-07-2007 07:04 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 09:38 PM
