Theres a small plastic elbow on the coolant header tank, it breaks, mine now has a brass one from the local hydraulics place. There was a discussion about it some time ago, It seems its quite common and easy to detect when the fuel tank is off.
They recommend to change you coolant every two years, I do it annually. Its your choice on that one.
An infra red heat detector is good for checking engine temps, can be bought quite cheaply these days from tandy stores (radio shack in the us?)
