Geoff, of course you are right, a bigger tank is the easiest and best solution if the aesthetics of the replacing take is acceptable. But this time around it didn't even occur to me. Years ago I had an XT500 and SR500 (older siblings of your Tenere) and was able to buy an oversized enduro tank for it; beautiful in its function.
I did look at metal gas tanks that people had cut into three pieces the long way and added 2" to each side of the tank. And Ambassador and Eldorado guzzi tanks lengthened to fit on modern Guzzis for that retro look. Both methods increased capacity to 7+ gallons. I don't have the cash to pay someone else to do a project like that and don't know if I'm a good enough welder to do it myself.
Has anyone tried setting other tanks down on the Legend? I have an extra SP100 tank I could try but I just broke my ankle and won't be in the garage for more than a month. Though I do like the looks of the Guzzi tank, the stock legend tank so cries Triumph.
I looked at the purpose built tanks that sit on the seat or rear rack. They were all expensive and that place on the seat and rack is where I pile most of my gear when traveling. Giving up the right side saddle bag space was less of a loss for me and put the fuel in the second best place for handling (the best is in the tank).
What you see is my third incantation of this project; each one working better and safer. Were I to this again, I would use the 3 gallon cell below that is already metal clad and can be purchased for $126.00
http://store.summitracing.com/partde...5&autoview=sku
If I wanted a cell for use only on trips, I would have mounted this tank on my seat and used gravity feed to the fuel lines.
