Hi Nick, pleased to hear it's going well
David
I agree that you'll need to check the carb jets & needles for part nos. Maybe no harm as with that low mileage the carbs & jets may well need a good clean out. Problems with blockages from gas residue seem very common on bikes that have been laid up for while, often over the winter in many parts of the US.
I've not long fitted a Dynojet kit (TBS kit that fits the Legend) & found their advised settings to be rich. (Have K&N filter & aftermarket 'freeflow' 3-1 exhaust.)
The long & the short is that the DJ needles are very good & fill a slight lean flatspot in mid revs on these bikes, but doesn't need much if any increase in main jet size.
So aftermarket jetting may be the problem also.
Note that the throttle cable is hard to detach at the carbs & the bending required often shortens the life of said cable. (They always seem to break here - carry a spare, it's about the only thing you'll need to carry.) I don't generally detach the cable, just slide them out to the right & set them down on a 'workmate' or similiar.
A good balance is essential for smooth running too - the adjusters are very sensitive, 1/8 of a turn & they're miles out. A recheck of balance is needed after every removal & refit imo. 6,000 mile service item IIRC.
Space around the carbs is tight - you'll wonder how on earth they come out 1st time - but they do, just.
Congrats on the new bike, you couldn't do better - your wife too, what a diamond
