Front End Wobble 2000 Tbird - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-05-2009, 09:09 PM   #1 (permalink)
Favourite Bike: 77 T140V- 750 BONNEVILLE
Other Motorcycle: 00 900 THUNDERBIRD
Have A Front End Wobble When I Let Go Of The Bars At Low Speed- Quite A Worry..............front Wheel Bearings? Steering Head Bearings? Any Thoughts Most Appreciated........jeff
IN TIMES OF PEACE, PREPARE FOR WAR!!
TRUMPYJEFF is offline   Reply With Quote
Old 01-06-2009, 08:30 AM   #2 (permalink)
Favourite Bike: '99 Legend / '98 TBS
BigAl8295's Avatar
Could be something as simple as tire pressure or tire wear.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 01-06-2009, 12:03 PM   #3 (permalink)
tiz
Favourite Bike: T-Bird
I would go with tyre wear or pressure I`ve had front end wobble at low speeds approaching junctions tyre looked ok at a glance but look more closely to the centre and it was cracking had a new front tyre correct pressure problam sorted.
Tiz
tiz is offline   Reply With Quote
Old 01-06-2009, 03:19 PM   #4 (permalink)
DLK
Favourite Bike: 98 Leg End
DLK's Avatar
I had a similar problem on a bike after fitting a new front tyre- turned out to be made out of round. It gave me a low speed ocillation with one hand off. Fix it, quickly! Tank slappers are proper scary.
DLK is offline   Reply With Quote
Old 01-06-2009, 05:11 PM   #5 (permalink)
Favourite Bike: moto guzzi sp1000
toller's Avatar
Other Motorcycle: triumph legend TT
Extra Motorcycle: KX80
in addtion to the other suggestions...
look to your rear tire pressure
some amount of ossiclation can occure without anything being "wrong", surface conditions, steering geometry, weight and seating position can all have an effect.
toller
aka leo in saint louis
2001 Legend TT
1979 Moto Guzzi SP100
photos http://www.triumphrat.net/memberalbu...ry.php?cat=983
toller is offline   Reply With Quote
Old 01-06-2009, 09:29 PM   #6 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Another possibility, if you happened to adjust the chain just before it started is the rear axle alignment. Another thing to check, as all of the above can cause it also.
Cheers,Denny
denny is offline   Reply With Quote
Old 01-17-2009, 08:42 AM   #7 (permalink)
Front End Wobble
Thanks for your replies fellas;
The tyres are new & pressures fine, Im thinking maybe they didnt balance them afterwards.........
They didnt touch the bike, I took the wheels in.
I never let anyone touch my bikes. I'll have to get one of those tyre fitting jigs & a balancing jig eventually................
I couldnt be bothered with tyre levers, you can damage your rim getting a tyre on or off.If you want something done proper, you have to do it yourself.........Regards jeff
Old 01-17-2009, 10:54 AM   #8 (permalink)
BigAl8295's Avatar
Uh, except in this case. Seems like it would have been better to just let them do the whole job.
Old 01-26-2009, 12:35 PM   #9 (permalink)
Favourite Bike: 1997 Triumph Thunderbird
Other Motorcycle: 1959 Sears/Puch Allstate
Is it a constant wobble or is it more of a wandering sensation at lower speeds? My Thunderbird developed a wandering after my last tire change so I thought something was wrong with the tires the dealer fitted. It turns out that the headstock bearings need replacement and the tires/wheels are fine. Maybe you are experiencing something similar.
Noel
Falcon_52 is offline   Reply With Quote
Old 01-26-2009, 02:00 PM   #10 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
balancing - schmalancing
I took my tire weights off, installed dyna beads, and haven't looked back! No vibration issues, and smooth as silk at any speed. Yeah, I was skeptical, too, when I read the stuff on their website, but honest, they work!
ssevy is offline   Reply With Quote
S4 front end wobble?? spdfour Triumph SuperSports 11 08-04-2008 01:28 AM
Front end wobble. jonkull Classic, Vintage & Veteran 2 09-24-2007 08:02 PM
Wee bit'o front end wobble? SR1 Sprint Forum 12 03-15-2007 09:41 AM
Front end wobble kelticwolv Sprint Forum 10 02-19-2005 10:10 PM
front end wobble cat Classic, Vintage & Veteran 1 04-24-2004 09:30 AM
