99 legend TT raising the seat height? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.com Classifieds!New BonnevilleOntario Tourism
Old 01-03-2009, 08:38 PM   #1 (permalink)
Favourite Bike: 98 Legend tt
bueller's Avatar
Other Motorcycle: SV1000N
Extra Motorcycle: 80 gsx1100
The Legend is even lower than the thunderbird and I was wondering how triumph lowered the seat height on the legend compared to the stock thunderbird.Is the rear shock and front forks shorter?I would like to increase the seat height as much as possible as I find it to cramped for my 6'3 frame.Thanks for any advice.
bueller is offline   Reply With Quote
Old 01-03-2009, 09:28 PM   #2 (permalink)
Administrator
Legend
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
As far as I remember the Legend has shorter rear suspension link-bones than the Thunderbird-Adventurer, maybe someone who has done this mod can confirm but I believe changing to the longer links will give you more height.
Ride on !
Tbirdnz is offline   Reply With Quote
Old 01-04-2009, 12:09 AM   #3 (permalink)
Favourite Bike: '99 Legend / '98 TBS
BigAl8295's Avatar
Changing the links will change the seat height, but if you don't change the front height as well you will screw up the handling.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 01-04-2009, 06:40 AM   #4 (permalink)
Favourite Bike: Legend-01
Other Motorcycle: Honda NTV 650 Revere
Legend is lowered by suspension, subframe and seat.
If you feel cramped when driving, then changing those dogbones isn't the answer. Actually with T-Bird's seat and the subframe you can have more "room", sitting higher comparing to your footpegs.
Changing dogbones and front fork springs changes only bikes centre of gravity point and you sit higher comparing to the ground level.
Proffa66 is offline   Reply With Quote
Old 01-04-2009, 10:12 AM   #5 (permalink)
BigAl8295's Avatar
He could have padding added to the seat to make it sit higher.
Old 01-04-2009, 11:35 AM   #6 (permalink)
Favourite Bike: 2003 Trophy 1200
Other Motorcycle: 2001 Legend TT
Talking
I had my Legend raised by changing out the longer dog bones for the shorter ones used on the Tbird. It raised the seat more than an inch and it is much more comfortable to sit while stopped. It also raised the bike's underbelly and makes cornering less of a sparks and hard parts affair. It probably doesn't affect the ride position but I feel more planted while stopped. Just a thought.
Flybiker
flybiker251 is offline   Reply With Quote
Old 01-04-2009, 12:23 PM   #7 (permalink)
Favourite Bike: 2000 Adventurer
Woody1911a1's Avatar
Other Motorcycle: 67 T100C
Extra Motorcycle: Buell Blast
this is how to lower a t-bird , just do it in reverse and make 7" dogbones . it will quicken the steering a bit .
Legend drop links will do the trick. These dog bone looking things on the rear suspension from a legend will lower it 1" & 1/4
Or you can make your own, 1"X1/4" mild steel flat bar. Cut to 8.5"
STock links are 7" centre to centre.
To lower 1 inch holes are drilled 7&1/4" c to c
To lower 1 1/2" 7&3/8" c to c
To lower 2" 7&1/2 c to c
Drop the fork legs through the triple trees a maximum of 5/8"
By the way I forgot to mention the holes in the drop links are 15/32" diameter
Woody1911a1 is offline   Reply With Quote
Old 01-04-2009, 12:26 PM   #8 (permalink)
Favourite Bike: my 1999 triumph legend
ssevy's Avatar
lower pegs can help
If you are talking about being cramped because of the lack of room between your hips and your feet, try aftermarket pegs which are flatter in profile, and give you a bit more room. I changed to a Triumph King/Queen seat and Kuryakyn pegs, which gave me more room, and eased the tension on my hips. Custom seat adjustment would be even better, but too much height may then make the handlebar position uncomfortable, and possibly affect the handling in a negative way. I'm 5'11", and have a 30" inseam, and I am just comfortable on my Legend. I've always thought this bike would be a perfect fit for someone shorter, as the fit is close, and the seat height allows both feet to be flat on the ground when stopped.
ssevy is offline   Reply With Quote
Old 01-04-2009, 10:59 PM   #9 (permalink)
bueller's Avatar
I am after both more ground clearance and more leg room.I did not realize the sub-frame was different as well maybe I should have waited till a thunderbird came up.I like the wheels and the blacked out motor.Any one want to lower their Thunderbird?
Old 01-05-2009, 06:09 AM   #10 (permalink)
subframe
http://cgi.ebay.com/ebaymotors/Parts...3A1|240%3A1318
This is only subframe I could find. Needs paint.
If you change also your dogbones to shorter ones, buy also progressive front fork springs. I have no idea how Legends front forks are different comparing T-Birds, but I remember that I read somewhere that Legends front fork springs are shorter than T-Birds.
Need help raising 99 legend rear lephturn Maintenance & Workshop Talk 1 10-07-2008 08:49 AM
Raising the Overall Height of the Bonnie rmak Twins Technical Talk 3 11-10-2007 09:45 PM
Raising the ride height 955iLimited Daytona Deliberations 3 05-25-2007 05:15 PM
Seat Height Bonithol Trophy 6 05-16-2005 11:12 AM
Raising Seat Height Maintenance & Workshop Talk 6 05-27-2004 10:54 AM
