Curing Cold TBird Bloodedness? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-02-2009, 10:31 PM   #1 (permalink)
Favourite Bike: 03 TBird
Beemie's Avatar
Other Motorcycle: OIF Bonnie
It takes a good 5 miles to get past the hesitation in cool, let alone cold, weather on our '03 Thunderbird.
Is there a cure short of risking fouling the plugs with the choke all that time?
Beemie is offline   Reply With Quote
Old 01-02-2009, 11:39 PM   #2 (permalink)
Administrator
Legend
Favourite Bike: '98 Triumph Thunderbird
Tbirdnz's Avatar
Other Motorcycle: '05 Honda CB1300
Just checked the current Connecticut weather and it's -6c !
I would say you were lucky to start the bike that cold !
.....but then I'm only guessing Don't experience such low temperatures here in the North Island of NZ.
Ride on !
Tbirdnz is online now   Reply With Quote
Old 01-03-2009, 12:15 AM   #3 (permalink)
Favourite Bike: '02 T-Bird
Iridium plugs?
Rode here in SE PA on New Year's Day - temp was about 34 F when I fired the bike up. Started immediately, with a little choke (about 2 minutes) while I pulled on helmet, gloves, and checked over the bike. This has been my experience with Iridium plugs, although I realize that 34 isn't extremely cold.
jonathanrsr is offline   Reply With Quote
Old 01-03-2009, 09:51 AM   #4 (permalink)
Favourite Bike: '99 Legend / '98 TBS
BigAl8295's Avatar
When I had my stock carbs, I always let it warm up a few minutes before hopping on and riding. I never had a problem.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is online now   Reply With Quote
Old 01-03-2009, 09:53 AM   #5 (permalink)
Nature of the beast
They're cold-blooded by nature. Installing a K&N air filter makes them even more so. I leave the choke on a little for the first couple miles and then take it off once the engine is warm. Never fouled a plug...
mulvaney is offline   Reply With Quote
Old 01-03-2009, 09:53 AM   #6 (permalink)
Beemie's Avatar
I'm talking when it's in the mid 50s and low 60s.
It's a good 10 to 15 minutes before it's responsive and has been like that since new.
So which jets are to fiddle with?
Old 01-03-2009, 10:58 AM   #7 (permalink)
Favourite Bike: 1996 Adventurer
Other Motorcycle: 2000 DRZ400-S
Extra Motorcycle: '99 Ninja 250,'04 KDX200
I was forunate enough to snag a cheap ($50) jet kit on e-bay. It cured the cold, lean, settings easily. Unfortunately, the most important part (the needles, in this case) are not available individually.
gregp is offline   Reply With Quote
Old 01-03-2009, 03:18 PM   #8 (permalink)
Favourite Bike: '99 ThunderLegendSprint
IrlMike's Avatar
Other Motorcycle: Wouldn't mind a Tiger 800
Extra Motorcycle: Can't ride more'n one...
Definitely not my experience that my 99 Legend (same Keihin carbs) is coldblooded (or my previous Tbird). Choke is off within 400m summer (~20c if we're lucky) or winter (~4c). Engine fully warm in ~2 miles, riding slow (max 50mph) until then. Have K&N filter & Thunderbike 3-1 pipe mods.
My best guess why this machine won't play is the pilot screw setting, known to be very lean as stock. I'm using stock jets but screws are 2.5 turns out. But maybe check all the clamps etc. to be sure an air leak isn't leaning things out.
Legend chassis, Tbird tank/seat, Sprint fairing, tubeless wheels, Thunderbike 3-1, air box mods, 115/40 jets, DJ needles, Ignitech with TPS, ZX6R shock, ZX7R USD forks/yokes, Alcon 6 pot
IrlMike is online now   Reply With Quote
Old 01-05-2009, 08:40 AM   #9 (permalink)
Petrol's Avatar
Are you running the plugs for cool weather? Original plugs were dpr9 ea 9 or somthing like it .They then changed em to a warmer running plug dpr8 ea9.I asked a ngk rep at the uk bike show why? He explaind that the bird came down between two plug parameters, go figure!
Petrol is offline   Reply With Quote
Old 01-05-2009, 03:52 PM   #10 (permalink)
tiz
Favourite Bike: T-Bird
cold blooded
I have a 95 T-Bird with dpr8ea9 for winter and dpr9ea9 for summer.
-6 degrees here this morning bike up to temp within 2 miles always ride with choke on for first 1 or 2 miles never heard of fouling plugs.
Tiz
tiz is offline   Reply With Quote
Swap parts from 98 Tbird to 02 Tbird Hinckley Classic Triples 5 06-11-2009 11:10 AM
Cold Weather/Cold Tires LoVel Biker Hang-Out 6 11-19-2008 07:42 PM
Curing the clunky gearchange on '05 S3, How-To Martin_R Speed Triple Forum 10 02-16-2006 10:06 AM
tbird sport carb rubbers for tbird & legend Spooner Hinckley Classic Triples 14 08-11-2005 02:45 AM
can a newer tbird 6 speed be put on a 98 tbird? 00wabbit Hinckley Classic Triples 17 03-30-2005 10:18 PM
