worry? - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 12-31-2008, 10:04 AM   #1 (permalink)
Favourite Bike: 2000 Legend TT
worry?
I put the TORs on my otherwise stock Legend -00.
A/F screws are out about 3 turns and when it is warm it answers the throttle good, but the right hand side cylinder does not get as hot as the other two, it takes a while. I will sync the carbs, but it runs good.
I drove it with the other mufflers then the cylinders where equally hot, since I switched to TORīs and rode it it was 3 days, so I do not think the carbs are fouled.
Could it be that the A/F screw on the right cylinder isnīt exactly as the other two?
Think itīs too soon to pull the new plugs to check, just wanna know if it is something to worry about.
Sweden is offline   Reply With Quote
Old 01-10-2009, 01:46 AM   #2 (permalink)
Favourite Bike: moto guzzi sp1000
toller's Avatar
Other Motorcycle: triumph legend TT
Extra Motorcycle: KX80
Doesn't sound like you are noticing something dramatic. And its hard to really tell how much hotter/cooler 1 cylinder is from another. Ride the thing. Do pull and compare the outer plugs (the easy ones) if you're worried, then get on with enjoying your machine.
toller
aka leo in saint louis
2001 Legend TT
1979 Moto Guzzi SP100
photos http://www.triumphrat.net/memberalbu...ry.php?cat=983
toller is offline   Reply With Quote
Old 01-10-2009, 03:55 PM   #3 (permalink)
toller's Avatar
Found a post that may also be of use.
http://http://www.triumphrat.net/cla...ml#post1115372
with my broken foot, have all day to scan the old files. Here is a comment on the settings being different between the cylinders.
http://http://www.triumphrat.net/hin...tml#post136957
toller
2001 Legend TT
Old 01-31-2009, 06:07 PM   #4 (permalink)
toller's Avatar
Come to any conclusions?
toller
2001 Legend TT
Old 02-01-2009, 03:34 AM   #5 (permalink)
Nothing yet, the links you provided does not work.
I talked to a local Triumph dealer and I am going to let them adjust the valves and sync the carburettors and then put in larger mains and adjust the mixture screws with a gas analyser, all this will no cost more than about 300$.
When it comes to TORīs and otherwise stock airfilter etc, they usually put in 102,5 mains and 3 turns on the mixture screws, according to them they run fine after that.
Dont Worry doodledog Biker Hang-Out 10 04-14-2008 08:10 AM
Sound to worry about??? tomster Twins Technical Talk 28 01-21-2008 11:14 AM
Too much oil - a worry or not ? FifeTiger Tiger Workshop (archive) 9 01-08-2007 11:40 AM
I Got Seepage. Should I Worry? Ramjet Twins Technical Talk 6 07-28-2006 01:55 AM
Like we didn't have enough t worry about... Nathan Twins Talk 8 06-23-2006 04:39 PM
