12-24-2008, 06:50 PM
Grand Prix 500 Favourite Bike: 1996 Triumph Adventurer
Posts: 135 Other Motorcycle: 2000 Yamaha RS Venture Extra Motorcycle: 2001 Kawasaki Nomad FI
Sprag Clutch Vin
I have a 1997 Adventurer. What VIN's have the sprag clutch prob?
Mag00
12-24-2008, 10:44 PM
Site Supporter Moto Grand Prix Favourite Bike: '98 Thunderbird Sport
Posts: 2,585 Other Motorcycle: '06 Husqvarna TE 610 Extra Motorcycle: '95 TBird - Project
I don't know which ones had problems, but here's numbers from the parts Fiche.
Sprag Part #........Engine #
T1221025 ...........> 109315
T1221035 ...........109316 > 114565
T1221025 ...........114566 > 114892
T1221035 ...........114893 >
Cheers,Denny
12-25-2008, 06:08 PM
Supersport 400 Favourite Bike: T'bird/Trophy hybrid
Posts: 84 Other Motorcycle: Toad King Extra Motorcycle: XS650 Yam
If it was going to fail, would it not have done so after 11 years?
I made the same enquiry direct to the tech dept at Hinckley, who said the whole sprag clutch issue was a result of bad press reporting and a very small number of failures.
Maybe that is what they WOULD say, maybe not.
Just ride the damn thing!
12-26-2008, 09:53 AM
Site Supporter Pole Position Favourite Bike: 1996 Thunderbird "Nessie"
Posts: 3,563 Other Motorcycle: 1973 Trump TR7RV "Loosie" Extra Motorcycle: 1968 BS 350 GTR "Smokie"
Originally Posted by 2 wheels good 3 better
If
Depends on where the bike lives, they fail more often in colder climes with harder starting conditions, and often on folks with weak or neglected batteries. The '97 version was stronger than the pre-96, and they continued to make improvements. This is a good question though!!! It might be hard to find the answer, since the part numbers were replacements. I doubt your going to find a VIN on the fiche. Maybe an old tech service bulletin is lying around?
12-26-2008, 01:37 PM
Not in this case. This motorcycle had only 1802 actual miles on it when I bought it. So I doubt there was enough wear and tear, or whatever, on the sprag clutch to cause it to fail. Thing is, from what I have seen while disassembling and reassembling the motorcycle is that someone did some real shoddy work on it, most likely a dealer shop, and ended up causing it to run so badly that the owner got fed up with it and put it in storage. And why the carbs were screwed around with when it was nearly a new motorcycle is beyond me. The incident probably also ruined his attitude about Triumph in general.
Mag00
12-28-2008, 08:56 AM
Grand Prix 250 Favourite Bike: 1995 Thunderbird
Posts: 47 Other Motorcycle: Thunderbird Sport 1998 Extra Motorcycle: Estrella BMW R 26
Hallo,
I am from the Netherlands Forum i read a lot of sparg clutch problems here,but exclusively here the most time.
Netherlands and Germany ( adjacent state, with a lot of Thunderbird-Sport-Adventurer-Legend behind the USA ) no problems with sprag clutch.
Well it is known that the problem is in the CDI ( ignitor-box) unit the first PLV ( discharge plug) it give directly a sparks.
The replace CDI ( with fixed plug) pull out first the machine engine then a sparks,and defecate so the sprag clutch.
Probleems here are exclusively with earliest Trident.
Sorry for my language hope you can understand.
Cheers jan.
12-28-2008, 11:38 AM
This is a new finding for me Jan - thanks for the info. I would hate to "defecate" a clutch. (means to go crap - but we don't use it that way much!  )
I think all the bikes that came to the States had Gill CDI boxes, not PVL. The early bikes had PVL coils, however.
12-28-2008, 04:46 PM
Hallo Cafetbird,
@I think all the bikes that came to the States had Gill CDI boxes, not PVL. The early bikes had PVL coils, however.
Yes, and the PLV boxes are the sprag clutch problem of the early bikes,special the Trident-Trophy-Daytona.with PLV CDI from 1992 till 1995. and some early Thunderbirds, often with old in stock PLV CDI.
The chance the he broken, is small with a Gill, however its always posible just like kawasaki, honda,suzuki.
12-28-2008, 06:20 PM
Greetings All,
Did the early CDI controllers have too much spark advance on start up, causing the first power stroke to run the engine backwards and overloading the sprag clutch? I’m just curious, I have 35,000 miles on my ’09 Adventurer with no issues.
Cheers,
Ken
Ken T.
12-29-2008, 06:08 AM
Originally Posted by towersk
Greetings All,
Cheers,
Ken
To fast spark advance, and start up, and overloading the clutch,split of a second.
Same as you start up with the gear in,that symtoon.
Butt you understand it well.
Cheers jan.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Sprag Clutch
Fridgehq |
Hinckley Classic Triples |
15 |
05-26-2010 05:37 PM |
sprag clutch help
drgonzogoo |
T3 Sport / Touring Forum |
2 |
09-16-2008 04:47 AM |
SPRAG CLUTCH
Fridgehq |
Daytona Deliberations |
5 |
07-15-2008 04:39 PM |
sprag clutch
desmo9 |
3 |
04-01-2006 04:50 AM |
Sprag clutch
steptoe |
Maintenance & Workshop Talk |
8 |
03-19-2006 05:43 PM |
