Thunderbird Sport - adjusting suspension? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-21-2008, 01:28 PM   #1 (permalink)
Favourite Bike: Thunderbird Sport
i've just bought a thunderbird sport (which i absolutely love) and i've noticed that the suspension is quite hard. i looked in the manual to see how i can soften it and it has a chart with numbers depending on the settings you like. so, i went out to the bike with my screwdriver expecting to see some numbers on the adjustment points. however there weren't any. should there be or is it not quite that simple?
rogoff is offline   Reply With Quote
Old 12-21-2008, 01:35 PM   #2 (permalink)
Administrator
Favourite Bike: '04 Thunderbird Sport
Wombat's Avatar
Other Motorcycle: I wish!
Welcome to the forum and congrats on buying the best bike out there.
Take a look at this page:
http://www.thunderbirdsportriders.ne...Supplement.htm
It shows the various settings along with diagrams.
Bob
Click to see My Photo Album
Age is of no importance, unless you are a cheese.
Wombat is offline   Reply With Quote
Old 12-21-2008, 01:44 PM   #3 (permalink)
hi bob, thanks for the info. that's what i've been looking at in my manual but i'm still confused. for example, it says "The motorcycle is delivered from the factory with the spring pre-load set on position 6." when i look at my bike, i can't see the number 6 anywhere. should i be looking for an actual number or a number of graduation lines?
Old 12-21-2008, 02:34 PM   #4 (permalink)
Administrator
Wombat's Avatar
There are no numbers, just graduation lines or clicks, depending on what you are adjusting.
Bob
Old 12-21-2008, 03:45 PM   #5 (permalink)
great, thanks for the info
Old 12-21-2008, 03:49 PM   #6 (permalink)
Favourite Bike: '04 Triumph TBS
cpallen's Avatar
Other Motorcycle: '05 BMW R1200 GS
Suspension Adjustments
The damping adjustments are made by turning the adjusters clockwise (in) to the stop. Then turn the adjuster counterclockwise (out) counting the 'clicks' or detents to the recommended/desired setting.
The preload adjustments for the front refer to the graduation lines visible in the threads.
The rear spring preload can be adjusted with a special shock spanner tool or a big screwdriver and hammer. If you aren't familiar with this type of adjustment the two rings are tightened into each other to lock them in place.
There's a specific process to follow for adjusting your suspension beginning with 'SAG' which is controlled by the preload adjustments. Google for "motorcycle suspension set-up" or try the following articles. You'll need a buddy or two to help you do it right.
http://www.motorcyclistonline.com/ho...tup/index.html
http://www.motorcyclistonline.com/ho...ing/index.html
Good Luck!
Courtney
cpallen is offline   Reply With Quote
Old 12-21-2008, 04:23 PM   #7 (permalink)
thanks - it sounds like it needs a bit of knowledge and care. i'm glad i didn't just start unscrewing things without asking first. much appreciated.
Old 12-21-2008, 05:23 PM   #8 (permalink)
Favourite Bike: 1958 Norton Nomad
Greaser's Avatar
Other Motorcycle: 2000 Triumph TBS
Before you touch your suspension settings, write them down on a piece of paper. Do not make too many adjustments without first test riding the bike.
Have fun!
" If you haven't been paying attention to what's going on in the world around you perhaps you should start. It certainly beats relying on erroneous rhetoric to form one's opinions." Steven Lloyd
Greaser is offline   Reply With Quote
need some basic info on the Thunderbird/Thunderbird Sport ohiorider Hinckley Classic Triples 23 12-06-2010 12:49 PM
adjusting suspension on Trophy evilletrophy T3 Sport / Touring Forum 3 05-12-2007 11:23 AM
ADJUSTING SUSPENSION Sport Sprint Forum 11 09-14-2006 08:36 AM
Adjusting Suspension RATLanta Sprint Forum 2 08-06-2006 07:05 PM
adjusting rear suspension moschika Twins Talk 2 07-31-2005 06:16 PM
