Thruxton battery relocation tray - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Group Buys and Specials This section is to notify members of specific group buys and specials that Site Sponsors, Vendors and Triumphrat.net may have on the go.
 5Likes
post #21 of 132 (permalink) Old 07-27-2013, 05:38 AM Thread Starter
fityfive's Avatar
Originally Posted by casida View Post
Looks like this might have a bit of a time fitting with the EFI considerations (ECU thickness and so on.) I've already got that very same battery, and it fits in the ARK setups I've seen thus far that are more readily designed for non-EFI, but this looks just a TOUCH shallow?
Dunno if you have a decent option for testing the EFI situation locally, but that might be good to know. =) Just my two cents. Or more, if I can end up buying one from you all.
Not sure about the EFI set up, this was originally designed for my bike 2006 ( carb ) and I haven't fitted it to any other model, and I'm not able to. I'm not sure what you mean about ECU thickness? Does the ECU unit have to be located in the tray along side the battery? What I do know is everything that is on or in the air box of the carb models fits into these tray's, if there is an ECU unit or extra wiring on the injected models it may not fit.
If the dog didn't stop to sh*t he would've caught the rabbit!
fityfive is offline
post #22 of 132 (permalink) Old 07-27-2013, 08:44 PM Thread Starter
fityfive's Avatar
The brake reservoir is a Triumph accessory part.
fityfive is offline
post #23 of 132 (permalink) Old 07-27-2013, 10:31 PM
Main Motorcycle: 13' Thruxton
How big is the ECU guys?
Joe_Mick is offline
post #24 of 132 (permalink) Old 07-28-2013, 03:10 AM Thread Starter
fityfive's Avatar
You should be able to locate it on your bike, when you do let me know where it is because this could change things for those of you with later models.
fityfive is offline
post #25 of 132 (permalink) Old 07-30-2013, 02:51 AM
Main Motorcycle: 2010 Triumph Scrambler
Yeah, the ECU and ECU connector are pretty large. About the dimensions of the battery on the carb model in height and width, and about an inch or 25mm in thickness, total. In addition to both of those, you have the OBD-II connector, which is about 25mm by 50mm by 50mm. Also, I don't think the carbed model would have the atmospheric MAP sensor back there, either. Not sure if the fuse box is much different between the two, though.
I'll get exact measurements in a bit here for the ECU. One sec.
casida is offline
post #26 of 132 (permalink) Old 07-30-2013, 02:56 AM
With connectors, the ECU measures up to 10cm high, 13.5cm wide, 3cm thick.
casida is offline
post #27 of 132 (permalink) Old 07-30-2013, 03:41 AM Thread Starter
fityfive's Avatar
Thanks casida, well if the ECU has to go together with the battery and can't go anywhere else, then I don't think this tray is going to work for those who have the injected models, this is already a snug fit with relay, fuse box, etc.....
fityfive is offline
post #28 of 132 (permalink) Old 07-30-2013, 05:22 AM
Main Motorcycle: Bonneville
What a beautiful piece of kit. And an actual product, unlike what British Customs has been promising us for MORE THAN A YEAR.
But unfortunately a great many of us ride EFI bikes.
nicholastanguma is offline
post #29 of 132 (permalink) Old 07-30-2013, 12:53 PM
Main Motorcycle: Thruxton
I don't have an ark on my bike yet. I'm assuming that is a requirement for this product?
Sent from Motorcycle.com App
Jonnyv is offline
post #30 of 132 (permalink) Old 07-30-2013, 04:00 PM Thread Starter
fityfive's Avatar
Pod filters, jets, brake reservoir ( depending on your taste ) and extension on some of the wiring is all you need.
ThruxtonNewbie likes this.
fityfive is offline
Mockup battery tray 303frost Hinckley Classic Triples 42 04-28-2013 10:42 AM
Battery tray tsx123 Air Cooled Twins Technical Talk 2 05-19-2012 05:07 PM
Battery tray Russ Club Cafe' 2 04-11-2010 07:49 PM
Battery relocation kit? Bhodi513 Air Cooled Twins Talk 1 06-17-2009 10:48 PM
battery relocation question diamonddog Air Cooled Twins Technical Talk 5 05-14-2009 01:04 PM
