Motorcycle.com
Gear & Gadgets We all use em - Helmets, Jackets, Gloves, Electronics! Share what you know and find out what you don't.
Old 11-03-2007   #1 (permalink)
Favorite Bike: 07 BB
Skvarki's Avatar
Triumph Accessory Outlet
I had the OEM outlet installed on my 07 Bonny but the receptacle is too small to fit regular 12V cigarette type plugs. I wanted to get some Gerbing heated gloves and I'm not sure what I need that will fit/work with that outlet.
Is it a BMW style connector that Triumph uses? Or do I need a special adapter so that I can plug regular North American 12V cigarette plugs into it? Has anyone out there done it with Gerbings?
Thanks!
Skvarki is offline   Reply With Quote
Old 11-05-2007   #2 (permalink)
Favorite Bike: Y2K RS
chefjpd's Avatar
Other Motorcycle: 750 Monster
It's a powerlet plug. Most all european bikes use this type of connector.
You can fins all the parts required to change the plugs at the following link:
http://www.powerletproducts.com/products.php?mid=1
I have enough money to last me the rest of my life, unless I buy something.
chefjpd is offline   Reply With Quote
Old 11-14-2007   #3 (permalink)
The BMW plug is what you need. I picked a couple up at the local Motorad dealer. Easy to install on my heated vest. Picked up a second for my cell phone charger too.
Paul
It's not just a motorcycle...it's my Triumph!
Paul955I is offline   Reply With Quote
Old 01-16-2008   #4 (permalink)
Favorite Bike: 05 Sprint, Wife, & Kid
jeffro's Avatar
Other Motorcycle: Riding Mower/Aussie
Extra Motorcycle: 8 yrs old Daughter
battery Tender into it
Does anyone know if I can plug my Battery Tender in to it. I see they make a plug for it. How does that work. You are putting power into the plug instead of getting power from it? I'm not electrical savvy.
high back risers Corbin Gunfighter and lady Corbin Back rest for the Lady Frame Sliders (After a drop outside of Hooters) :( TOR can and tune M PP 2 CT tires Pazzo shorts,Stebel Horn, Homemade (OnD Style) Throttle Meister, Givi DB, 18t front
jeffro is offline   Reply With Quote
Old 01-16-2008   #5 (permalink)
Favorite Bike: 2007 Bonneville T100
Other Motorcycle: 2006 Kymco People 250
Yes, with the proper SAE --> Powerlet adapter you can plug your battery tender into it. Works fine. I've already tried it on mine.
I did have to buy several adapters for:
- Widder (Proprietary)
- Gerbing (Coax)
- Battery Tender (SAE)
Everything works fine in the Powerlet AKA Triumph AKA BMW accessory socket, and it is a lot neater than having several different cords running out from the battery. If you need a cigarette lighter adapter for a 12v air pump or something, they are also available. My Cycle Pump is SAE, so I didn't need that.
Paul
2007 Triumph Bonneville T100, Tors, xAI, xSnorkel, 120 mains / 1 shim, 40 pilots, 3.0 turns, NH Bellmouth, Works Performance suspension, National Cycle Deflector DX, Scrambler Gel Seat
Pauljo is offline   Reply With Quote
Old 01-17-2008   #6 (permalink)
Favorite Bike: 2001 Sprint St
MVP44's Avatar
Other Motorcycle: 2003 GSXR 1000
I have the Gerbing kit and use the adapter to fit my battery tender and it works top notch. Be careful with the adapter you buy. there was an issue with polarity not being correct on older model adapters which should mostly be out of circ by now, but you never know. I went to a BMW dealer and he gave me one that is correct.
+1 on the Gerbing gloves - My only regret is that I didn't buy this stuff 20 years ago, but then again they probably didn't make them 20 years ago.
My coldest weather ride to date this year is 4 degrees F in the Catoctin mountains in Thurmont MD and I did not have either the jacket or accessories turned up on the high setting - enjoy
MVP44 is offline   Reply With Quote
Accessory Power Outlet boreilly Sprint Forum 4 12-26-2007 06:05 PM
accessory outlet hodgy Daytona Deliberations 2 12-05-2007 12:23 PM
Triumph Accessory outlet on Bonny Skvarki Twins Technical Talk 10 11-24-2007 01:52 AM
tiger accessory outlet pizzaman383 Tiger Chat 6 04-10-2007 03:45 AM
Accessory outlet on ST kgeissler Sprint Forum 7 10-17-2004 12:48 PM
