BikeBanditAdvanstarMotorcycleShowsShopTriumph.comMotorcycle.comTrident-Exhausts.com
Gear & Gadgets We all use em - Helmets, Jackets, Gloves, Electronics! Share what you know and find out what you don't.
Old 10-26-2007   #1 (permalink)
bonnieblackinfl's Avatar
Magnetic Tank Bag...Which One??
I'm sure that allot of people are using tank bags, but there are so many to choose from. What are some of your inputs and personal preferences/opinions? I have never used them, but I'm looking for something that doesn't cost a small fortune, and is large enough to carry some spark plugs, tools, wallet..etc. I would like something that is somewhat a low profile and doesn't get in your way while riding.
Your opinion counts, so post up!
Greg
bonnieblackinfl is offline   Reply With Quote
Old 10-26-2007   #2 (permalink)
mecscc's Avatar
Nelson-Rigg MG950. Indestructable. Expandable. life time warranty that never has to be used. I think they are closing them out but they can still be found on the internet at around $40..........
Monte
PS: Greg: it is virtually impossible to use a tank bag very much and not scratch the paint. It is pretty much inevitable. I tour all the time so I accept it, but were I ever to sell my Bonnie, I would repaint the tank first. I use touch up paint. Part of the problem is the paint on the Bonnie in the first place. The clear coat is very soft and the base coat is easily scratched as well. It acts more like spray can paint than a baked on finish. When I used the same tank bags on Hondas I had a few inconsequential micro scratches, but on the Bonnie one piece of grit under the bag pad will gouge a line in the paint if you don't pick up the bag with meticulous care. And that is way too much bother for me. Sue has the same bag and uses it every time she rides her Kaw Vulcan and there are no scratches.
Monte
"The Old Ohio Preacher Man"
Old 10-26-2007   #3 (permalink)
Favorite Bike: '01 Bonnie
ggRAT's Avatar
Kahedo Tank Bag
Bought this Kahedo Tank Bag from NewBonneville.com.
http://www.newbonneville.com/html/classic_tank_bag.html
It expands to twice the size pictured. Works great and fits the bikes lines.
GO:904cc/-AB/-AI/K&N/Jets:140,45,-1.5,3mm/Predators/ceramic headers/180 rear/Ohlins/Works/520GXW+19Tx43T
SHOW:Pazzo levers/gaiters/Oberon pegs/Naps/new lights/SS braided cables/68 flyscreen,seat & cowl ... View Album
ggRAT is offline   Reply With Quote
Old 10-26-2007   #4 (permalink)
They all cost too much. It's like a conspiracy.
I had the Cortech one. $80, has lots of room, expandable, map pocket and comes with a few straps for added security and carrying it around over your shoulder.
They can scuff the tank. I always make sure the bottom of mine stays clean. I've tried placing seran wrap down which has worked for the most part but it's inconvenient. Some bags have wetsuit material to help grip which reduces the microscratches somewhat. Make sure the bottom is clean and don't leave it on the tank allowing moisture to build up and don't get any gas under it when you fill up and be prepared to polish the tank once in a while.
Now I have a homemade one that I really like. It fit's all of my stuff. A small tool roll, spark plugs, ignition wires, flashlight, carmex, sunscreen, a pocketknife and maybe a few other items.
I was going to write up a DIY instruction to build it at some point. Basically, I used a canvas mechanics tool bag, (nylon is available, but costs a lot more):
Available at any surplus store for about $6.00 and some 2" donut magnets:
I got 4 from Fry's for about a buck. They're quite strong and hold the bag onto the tank while doing the ton. But, I have a strap that attaches to the frame in front of the tank with a clip that attaches to the front loop at the end of the zipper just in case. It also doubles as a strap to carry the bag off the bike.
I glued loop velcro to the whole bottom inside of the bag and the hook velcro to the magnets and put one in each corner. I also glued velcro on the side pockets since the snaps are hard to work while riding and I cut the handles off the bag. I also glued 2 8" strips of the loop velcro along the top on each side of the zipper. I have pieces of hook velcro, (adhesive backed) on the back of my mp3 player, cell phone and GPS so they stick to the top easily. Usually, I keep everything in the bag, my pockets or leave behind unless I go on a long ride, then it's usually just my mp3 player.
The canvas bag is mostly waterproof, but I treated it with a waterproofing compound to prevent mildew and add a bit more protection, (use a petroleum-based product, not silicone), I got a spray can of stuff from a camping store for about $5.00.
The velcro, straps and glue were "aquired" from work and past projects and I made the power adaptor from some wire and sockets I had in a pile of junk. I think I spent about $20 total. Of couse, buying everything might cost around $50 if you're not scrounging and recycling.
Weasel Pete is offline   Reply With Quote
Old 10-26-2007   #5 (permalink)
mecscc's Avatar
This might have to be moved to Gear and Gadgets. One of the super mods alerted me to that forum's existence. If it does I'll leave a direct link from here to there. This is a useful thread.
Monte
Monte
Old 10-26-2007   #6 (permalink)
Favorite Bike: 2007 Bonnie Black
OhioTT's Avatar
Other Motorcycle: 2003 HD Heritage Classic
There was an earlier thread about the need to be very careful where the bag was stored to avoid getting dirt on the bottom and then scratching the paint. I agree with Monte about the soft paint. My Harley's paint is far superior to the Bonne's.
2007 Bonnie Black
Emgo reverse megs,K&N filter,Polaris bellmouth,130 mains,stock pilots,three turns out,gaiters,to be continued......
OhioTT is offline   Reply With Quote
Old 10-26-2007   #7 (permalink)
Shhh! you're gonna get the thread locked. Triumph's are superior to Harley's in every way.
Old 10-26-2007   #8 (permalink)
Monte that is something like I am looking for and the price is right! How do the lines fit the tank? Do you have a pic of it installed?
ggRAT, that is the bag I was considering, but it is just so dang expensive. I like the way it really fits the top of the tank, it looks like it belongs there.
Pete, yes I agree. They are pricy and there is nothing really special about them.
Monte, if you have to move it, I understand. I thought that forum was for reviews of gear and gadgets? Well really this isn't a review; it is more of a specific inquiry for a specific style bike
Greg
Old 10-26-2007   #9 (permalink)
mecscc's Avatar
Here it is fully expanded when we were in N. Mich. last summer. It has two magnets in the bottom and one at the end of four legs. I like that on the Bonnie because you can fold the legs in front so that they sit above the logo badge. It has a small 9x13 or so footprint and is quite compact when not expanded. It has a mesh top inside section with places for pens, papers, cell phone, etc.
Monte
PS: I'm going to leave this thread here. It is useful.
Monte
Old 10-26-2007   #10 (permalink)
Favorite Bike: Do you have to ask?
TB-T100's Avatar
Other Motorcycle: Unfortunately not
Extra Motorcycle: Would love a Speed Triple
I am surprised that so few of you use / recommend the Triumph one. It is not magnetic, but the harness is quite easy to put on / take off, and it is a great piece of kit. I would definitely recommend it.
'04 T100 Black and White (because that is the only colour-combination to wear with a dinner jacket)
AI removed, TORS
rebuilt front (valves, springs, etc), Öhlins shocks
engine dresser bars, grab rail, flyscreen, Triumph leather panniers and tank bag
TB-T100 is offline   Reply With Quote
Magnetic Tank Bag for T100 - Debating Choices Pauljo Twins Technical Talk 37 09-03-2008 12:01 PM
Sheer desperation - magnetic tank bag solution? noobcorpse Sprint Forum 3 05-29-2007 01:05 PM
Tank Bag - Magnetic or Strap? 95TBird Hinckley Classic Triples 17 09-15-2005 12:39 AM
Tank Bag for Tbird. Magnetic or Straps? 00wabbit Hinckley Classic Triples 13 08-31-2004 09:56 AM
Magnetic Tank Bag or one with Straps? vonbonds Hinckley Classic Triples 2 04-11-2004 10:46 PM
