Motorcycle.com
Gear & Gadgets We all use em - Helmets, Jackets, Gloves, Electronics! Share what you know and find out what you don't.
Old 10-25-2007   #1 (permalink)
Favorite Bike: 2007 Sprint ST
Temp Controller drain my battery?
I just installed a WarmGear Heat-Troller Single Permanent-Mount Temp-Controller on my 07 Sprint ST.
It is connected directly to the battery.
What has me freaked is that with no electric clothing plugged in, when the potentiometer is turned from the "off" position the LED turns on.
Does this mean if I forget and leave it on or a passerby "sees what the nob does" I could find my bike with a dead battery?
As a side note - the Heat-Troller does not provide the output that my old Widder bi-metal thermostat did. I am hoping that it will be enough though....
shoen is offline   Reply With Quote
Old 10-25-2007   #2 (permalink)
Supposed to be a good controller - let us know how you like it. And from their web site:
When you turn the Heat-troller™ on or off you can feel and hear the positive snap of the switch. Because the Heat-troller™ is a solid state device, the switch controls the electronics not the power. This allows for the switch to have a true OFF position. But even if the Heat-troller™ is left turned on and plugged into a power source but unplugged from the heated product , the most power it will draw is just the power to flash the LED.
So essentially no power draw.
Be nice to America or we'll bring democracy to YOUR country...
vinnyf is offline   Reply With Quote
Old 10-25-2007   #3 (permalink)
I was going a bit further into their website and found the following. They were talking about someone having "copied" their circuit in China. Doesn't seem to be the situation with yours, but thought I'd pass it on anyway:
Is it a copy or a knock off? The Circuit is the same as our ver 6. The part designators are the same as on our ver 6 board. It has a flaw in the design so that if you have it turned off, but still plugged to power and ground the output, it will turn the LED on. This to us is a flaw. Maybe to others it is not but we replaced the Heat-trollers we sold with this flaw and only sold them for two weeks before we found the defect. We can provide you with the technical data that allows you to decide if it is a copy or a knock off. So, here is the test since now there is no other way to know if it is a Chinese knock off or not. Take the unit and plug it in to power. Turn it off. Touch the ground ring of the output connector to a frame ground like the handle bars or the metal tank. Does the LED turn on? Do you think it is OK for the LED to be on when the unit is turned off? If so then it is the Chinese knock off.
Possible battery drain? Panthers_Den Sprint Forum 10 07-27-2006 08:13 AM
Battery drain Ugarte The Rocket Science Forum 4 04-29-2006 03:29 PM
Heated Grip Controller Luficer_Toby Tiger Workshop 1 01-09-2006 07:11 AM
electric clothing & battery drain rickykarate99 Twins Talk 5 12-04-2005 07:49 AM
Run, Turn, Brake Controller yad Modifications & Workshop Talk 3 10-20-2004 02:04 PM
