Cramp Buster
I used a Cramp Buster recently and have mixed feelings about it. It goes on and comes off quite easily, and the rubber band is not needed for Bonneville grips. I tried it in several locations on the grip: left, center, right, and center worked best for me. However, using it seemed worse than not having it [I have M bars]. It was kind of awkward having a protrusion from the throttle while not at highway speeds; I always knew it was there. I got a numbness at the end of my fingers that was so noticable that I removed the piece. I found that with the M bars, my slightly forward lean can put sufficient pressure on the throttle that I can unwrap my fingers when needed to change up from the full grip and get a break.
Ahh, but for ten bucks, it's cheap enough to experiment with.
