Wombat-
Having tired of struggling with chain maintenance, I decided to purchase a stand for the TBS this year. After much Internet research, tearing of hair, and gnashing of teeth, I choose the SteelHorse. I went with the URS1-4. As far as I can tell the only difference (other than the obvious lack of swingarm spool function) is the URS1-4 comes in white. (Although I see now the website states one may call for availability in black)
Upon the stand's arrival, I had to remove the tension springs from the saddles to set them wide enough to fit on the TBS swingarm. The stand is sturdy, well made, and lifts without a hint of twist or buckling. The wheels roll smoothly and, overall, provides confidence when lifting the bike from it's sidestand.
I am well pleased with the stand. If you have no use for the swingarm spool brackets, I vote save the $30 (that is a couple of tanks of gas, you know!)
Cheers,
Jim
For I smell of the earth, and am worn by the weather....
