Also, BikeBandit.com sells new OEM parts for significantly less than dealers. They also have useful parts schematics.
I'm don't mean to hijack this guys thread, but I had to comment here. If BikeBandit is 'Significantly Cheaper' than your dealer; you need to find a new dealer! BikeBandit quotes 'Suggested List Prices for Triumph' to the penny. I've checked them a few time for parts and the prices were 'Exactly' what a dealer would quote right out of the book. A good dealer will do better too.
Now back to the original post. :-D
If you don't mind a non stock setup; I ran across
THESE while checking for a new regulator for someone. I think they look real nice with very simple mounting brackets supplied and the best thing was they seem real reasonable on the pricing. The most expensive unit listed is $199.00.
There is also Dakota Digital but the pricing is a joke IMHO, and they look to be catering to the chopper side of the market. The simple oval units looked good, but at $625.00 then you may need a few adapters I feel they are ripping you off.
The other option is used. I would recommend
Triumph Ant. Lots of people have used them and are very pleased with their service. They specialize in Triumph and do lots of custom swaps so they know which models will swap or work on other models. They are also shipping world wide on a regular basis so they have that covered for you as well. I'm sure you could find a salvage yard here that might have the part, but these guys have the know how to go with it. As mentioned always check E-Bay for a set if you don't need it right now. I think if you need to remain stock that the Triumph Ant is going to be your best option. I'm pretty sure they will guarantee the parts they send you and you will be sure to get all of the brackets and miscellaneous bits you may need at the same time and be done with it.
ElectroSport Gauges
Triumph Ant
BOLD = LINK
[ This message was edited by: Stlakid on 2007-05-01 16:47 ]
