| Gear & Gadgets We all use em - Helmets, Jackets, Gloves, Electronics! Share what you know and find out what you don't. |
03-09-2007, 09:22 PM
Team Owner Favourite Bike: 2005 Bonneville Blue 790
Posts: 5,897 Other Motorcycle: 1973 CB450, long gone
The Bonneville has limited access to the area over the valve stem on the rear wheel. Even some 45-degree service station air heads can't achieve the proper angle to pump air into the tire, at least when approached from the side of the wheel.
To get a modern bulky plastic dual-stem bicycle pump head on the rear valve stem is troublesome; I have to maneuver the entire head between the spokes to position it so I can flip the lever to lock it on.
Has anyone found a decent-quality bicycle pump with a head that can EASILY be attached to the valve stem on the rear spoked wheel, i.e. from the side of the wheel instead of threading it between the spokes? :???:
Marty
03-10-2007, 04:14 PM
World SuperBike Favourite Bike: 05 Black Speedmaster
You can buy 90degree ends for next time you have your tire off?
03-10-2007, 08:59 PM
For an inner tube???
Marty
03-11-2007, 09:38 AM
Valve stem extensions might be an option. Valve Stem Extensions
03-12-2007, 08:56 PM
Wouldn't those valve stem extentions throw your wheels out of balance?
Rick......................
03-12-2007, 09:04 PM
I bought a small air compressor (2 hp with 6 gallon tank) for under a hundred bucks just for filling up tires. I was able to find a small fitting for filling tires at the same place I bought my compressor. I got it at harbor freight.
03-12-2007, 10:31 PM
Formula Extreme Favourite Bike: 2008 1050 ST
Posts: 529 Other Motorcycle: 02 Sprint RS..sold
I did the same thing as sharpshooter,but bought from Canadian tire
and got a few air tools too.
03-13-2007, 11:55 AM
Thanks for the suggestions. I might eventually get a compressor and a fitting that's not a PIA, if for no other reason than I'd really, really like to blow the dirt out of the spark plug hole before I remove the plug.
In the meantime, is anyone using a bicycle pump that fits easily? The only decent ones I can find have the mega plastic Presta/Schrader head on them.
Maybe this is something that could be marketed to motorcyclists. All we need is a decent pump with a built-in pressure gauge (many are available) and a proper fitting at the end of the hose. Maybe there's a do-it-yourself way of attaching a different fitting?
Marty
03-14-2007, 07:59 AM
SuperStock Favourite Bike: 2003 Cardinal Red Triumph
I have this one. Click!
Just a few buck and works like a charm. Of course you need to go to Sweden to get it...
03-14-2007, 12:17 PM
Grand Prix 500 Favourite Bike: Triumph TBS
Posts: 115 Other Motorcycle: Only the one Extra Motorcycle: Want a Sprint RS
Same problem for the TBS. This is my solution, small and fits in your toolkit. Just clip it on the valve stem and it'll work anywhere.
Picked up the pieces at an auto parts store - $15. Sorry for the giant image, I was in a hurry when I posted it on my web site.
[ This message was edited by: TBirdVI on 2007-03-14 11:06 ]
Vern . . .
Vancouver Island
