Pinout for fitting your own alarm (or even just an LED flasher) - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda Powersports Ontario TourismSportbikeTrackGearMotorcycle.com Classifieds!
Gear & Gadgets We all use em - Helmets, Jackets, Gloves, Electronics! Share what you know and find out what you don't.
Old 06-15-2009, 10:35 AM   #1 (permalink)
Favourite Bike: Street Triple R
jsobell's Avatar
Lightbulb Pinout for fitting your own alarm (or even just an LED flasher)
It's so nice of Triumph to give us a lovely LED on the clocks showing that the alarm is turned on... or showing any savvy thieves that there's no bloody alarm on the bike because it's not flashing!!!
I'm just waiting for an Acumen CAT3.1 alarm arriving in the post, and thought I'd spec out the wiring required to fit it to the existing harness.
It's actually very simple, and shows that if you like you could create a dummy circuit for a few cents to flash the alarm LED, probably providing almost as much deterrent as a real alarm.
Anyway, here are the pinouts for the Daytona and Street-Triple, so I assume it's the same for all the latest Triumphs:
(This is the Triumph internal connector, NOT the external alarm connector)
1: Engine Run A - To instrument panel and ECM
2: Engine Run B - From fuel pump and engine stop switch (link to 1 to run bike)
3: Starter Enable A - To instrument panel and ECM (common with 1)
4: Ignition On (output) - Ignition on indicator (common with 2)
5: Starter Enable B - To engine start button (link to 3 or 1 to run bike)
6: +12v - Linked via Fuse 4 (10A)
7: Left Indicator - Link to +12V (pin 6) to illuminate
8: Right Indicator - Link to +12V (pin 6) to illuminate
9: 0v - Ground (common with 12)
10: LED- - Led 0V (-ve)
11: LED+ - Led +1.5V (Do NOT connect to 12V!!! Use 1K resistor in series for 12mA LED, 500ohm for 24mA etc.)
12: 0v - Ground (common with 9)
In summary, if your alarm has a single ignition disabler relay then connect it between 1 & 2, so nothing works if the alarm is enabled, but if it has a double relay use the other N/O circuit to link 3 & 5.
For the worlds most basic 'alarm simulator' just build or buy a simple LED flasher kit like this, or build your own. You may choose to replace the unused second LED with a high value resistor to save a few milliamps of battery usage.
I just got my Street Triple delivered 2 days ago but decided to forgo the DataTool S4 as it would take me about 10 years to recoup the cost on insurance savings, and I know from experience that a simple alarm with flashing LED discourages all thieves but those with a van, so buy a more cost-effective alarm and spend some of that saved money on a hugger, chain oiler, or oggie knobs instead!
My first Triumph and hence my first posting here, so hopefully someone finds this info useful, and if anyone's interested I'll post my findings after the alarm is fitted (otherwise I'll just shut up and go away ).
Cheers,
Jason
Last edited by jsobell; 06-16-2009 at 12:54 AM. Reason: Forgot to mention this is the internal Triumph connector
jsobell is offline   Reply With Quote
Old 06-16-2009, 06:08 PM   #2 (permalink)
Favourite Bike: Umm...Striple R
rsw81's Avatar
Other Motorcycle: FZ6
Very interesting idea. When you go to do this, can you please take pictures for a DIY guide?
rsw81 is offline   Reply With Quote
LED flasher question mep7851 Twins Technical Talk 16 01-19-2009 02:24 PM
flasher barneyharding Hinckley Classic Triples 3 01-16-2007 10:14 PM
flasher barneyharding Daytona Deliberations 2 01-15-2007 08:29 PM
Where's the flasher can? LaughingBob Twins Talk 2 04-19-2006 09:51 AM
flasher Hinckley Classic Triples 0 03-06-2004 08:15 PM
