Trying to chase down an issue; will TuneECU talk to the 2nd gen race ECU for the Daytona 675? I have the ECU, no copy of TRACS nor the TRACS key on a bike I just acquired.
The cable (possibly not a real Lonelec -- possible issue #1) appears to connect fine. Can read diagnostics from the ECU.
However, I get the infamous 'unknown map type' error. I have it listing '90003' as the map (which I can't find anywhere -- I assume it's the racemap?). I'm unwilling to try and load a new map since I have a PCV piggybacking right now, but I think the ignition is pretty far advanced for race gas and I'm running pump since I'm not making nearly the power I should.
I /think/ my only option is to drop a new map on it and start tuning from there, either with the PCV or with tuneECU. Is this correct?
Closing the loop. TuneECU works fine with this bike. Looking at mechanical (cam timing) issues on this thing
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
