T595 Map Question - Triumph Forum: Triumph Rat Motorcycle Forums
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
post #1 of 3 (permalink) Old 03-04-2017, 11:28 AM Thread Starter
Main Motorcycle: 1998 T595 Daytona
Other Motorcycle: 2000 Kawasaki ZX12R
Extra Motorcycle: 2005 HD XL1200R Sportster
Question T595 Map Question
It's been running fine with a Triumph high pipe and dealer downloaded tune except that it always ran rich. A couple of years or so ago I bought two S/S mid pipes, both a high and a low from a vender I read about on this site. They sat on a shelf until I found a Two Brother's Racing muffler for a Honda 600 on sale at a local dealer that had the same i.d. as the midpipe. I designed a mounting ring that I had machined and TIG welded by Burn's Stainless to the mid pipe to allow the muffler to be bolted on. It follows the seat cowl lines very well, is loud, runs good with the factory tune but....is another there another tune I should try? The only drawback thus far is the edge of the right rear turn signal is becoming distorted by the exhaust heat so I see a Sky King rear fender mod coming up. At about the same time that I purchased the pipes I ordered a recommended cable off Ebay. Just now I've downloaded the Tune ECU program, drivers and hex files. By following the excellent instructions from this site the cable is recognized, the program is opened and recognizes the interface as USB. After some "honey do's" I'm going to attempt to download and save the installed map to determine what map I have.
1998 Triumph T595 Daytona
2000 Kawasaki ZX12R
INhondo is offline
post #2 of 3 (permalink) Old 03-19-2017, 02:56 AM
Main Motorcycle: Daytona T595
Hangover's Avatar
With a custom exhaust you may need a custom map or dyno tune to get it running better, i had 9863 on my ecu when i got the bike which ran crap.
Switched to 9860 and its much smoother.
Hangover is offline
post #3 of 3 (permalink) Old 03-20-2017, 07:41 PM Thread Starter
Smile
I bought mine new in 1998 and at the first service bought the TOR high pipe. Mine is supposed to have the TOR high pipe tune but I want to be sure. It actually runs pretty good, burbles when decelerating, never a backfire or pop. I've downloaded and printed up a lot of the instructions so I'm going to try tomorrow to at least ID the tune. Thanks for the reply!
2000 Kawasaki ZX12R
INhondo is offline
Speed Four Stalling Issue Calkins Triumph SuperSports 35 10-15-2016 05:49 PM
2013 Thruxton EFI Map Question ctmtb Air Cooled Twins Technical Talk 4 07-02-2016 09:30 PM
TUne ECU MAP 20512 question -Scrambler Cotal Air Cooled Twins Technical Talk 8 04-25-2016 10:09 AM
ECU Map Question nbig Air Cooled Twins Technical Talk 5 07-18-2015 08:16 PM
T595 Fuel Filter question.... Captain Bob Daytona Deliberations 0 05-23-2015 07:19 PM
