hi
i have a 2013 sprint gt 1050 and according to tuneecu the number is 20610
does anyone know if there is an update on this in a standard tune
i ask because my brother has the 2015 model which is identical to mine but his is a lot smoother and faster on acceleration
i was not sure if i can use tuneecu on his bike to see what map he has as it might be tamperproof, so unsure if to try it
any help would be appreciated
cheers
had a look on my ecu and mine says 020609 so according to tuneecu my map is 020610 so is the updated one
my brothers 2015 one has no map number on it
see pis
any ideas welcome
i presumed 95 was our normal unleaded just double checking
the map i have on now is 20610 so according to the ecu i will put the 20609 on like you suggested
my ecu is the one with the 2013 date on
cant see any tune number on the 2015 one just a part number further down
where are you looking
cheers
2015 Triumph part number on ECU looks same as 2013. If 2015 ECU not locked, can connect TuneECU to ascertain tune number on top left of Map Edit screen ?
got connected to the 2015 bike and yes its the 20609 map so i saved it and will download to mine
only problem now is mine wont connect, think battery is a bit flat
cheers
Looks like 20609 promotes more fuel at high throttle openings. And 20609 provides up to 3-4 degrees more ignition advance. Will be interesting to see if those differences can be felt. Remember to reset adaptions after loading 20609.
finally got out on bike today
yes you can tell the difference between maps
the throttle response is quicker and smoother
thanks for your help with this
cheers
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
