12 Scrambler, dirty OBD port, covered in goop / wax - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
ECM and FI Tuning - Help, Tips & Tricks We invite members from across TriumphRat.net to post your questions, or share your expertise or experiences on TuneBoy, TuneECU and PowerCommander (etc).
Old 12-12-2012, 05:10 PM   #1 (permalink)
Main Motorcycle: 12' Scrambler
warrewp's Avatar
I searched and searched and couldn't find anything on this, but my OBD port on the bike appears to be covered in some kind of goop or wax. Has anyone else seen this? Also, any recommendations for cleaning it off before I connect my OBD cable? I just got this OBD from TTP, and I don't want to mess it up by connecting it to the dirty port. I don't want to damage the port in cleaning either, but I was thinking of trying to use q-tips with just a little bit of water.
My bike is a 2012 Scrambler...
warrewp is offline   Reply With Quote
Old 12-12-2012, 08:25 PM   #2 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
champ87's Avatar
Extra Motorcycle: 1973 Yamaha RD350
Don't clean that "goop" off - it's supposed to be there. It's dielectric grease applied at the factory to keep out moisture and prevent corrosion on the terminals.
From that description you should be able to figure out that using water to clean it off will not be very effective. If for some reason you got dirt in there then mineral spirits might be your best option for cleaning but after cleaning you should apply some more dielectric grease to protect the connector.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline   Reply With Quote
Old 12-12-2012, 09:55 PM   #3 (permalink)
warrewp's Avatar
Thanks. I think they went a little over board with the grease then, But I wasn't aware that that's what it is... I will carry on then.
Old 12-13-2012, 03:51 PM   #4 (permalink)
Main Motorcycle: 2004 Bonnie Black Special
PieMan's Avatar
They are all pretty much like that, it's not a problem and won't effect the OBD2 cable in any detrimental way.
Mike (UK)
PieMan is offline   Reply With Quote
Old 12-13-2012, 04:37 PM   #5 (permalink)
Main Motorcycle: Speedtriple!!
triplestrength's Avatar
Other Motorcycle: Triumph Trophy 900
Extra Motorcycle: Honda CB400AT
I just fitted heated grips to my Rocket3 they are Triumph ones and all the connectors were full of this grease it keeps water out and corrosion away!
Sent from my GT-I9100P using Motorcycle.com Free App
triplestrength is offline   Reply With Quote
Old 12-14-2012, 11:52 AM   #6 (permalink)
Main Motorcycle: 2011 Speed Triple
It may look like a lot but it really isn't overboard. I would just leave it be. Mine looked like that too on my Speed 3 and had no problems at all connecting a cable to it on multiple occasions.
djn876 is online now   Reply With Quote
Old 12-18-2012, 04:44 PM   #7 (permalink)
Main Motorcycle: EFI Bonny
yes sir. good to go
ALLTRIUMPH is offline   Reply With Quote
Newbie from the dirty dirty sandyman4090 The Welcome Center 0 10-09-2012 06:41 PM
Any Goop Needed - Mufflers? norton828 Twins Technical Talk 3 04-09-2012 06:55 AM
Removing burnt on goop from exhausts Halofaller Trophy 1 02-03-2009 06:50 PM
Dirty Dirty... Wom... Oh wait that will attact to much attention... Prestimp Speed Triple Forum 14 11-03-2006 10:18 PM
punctureseal, ultraseal, slime or goop davsato Sprint Forum 11 05-18-2006 06:53 AM
