low fuel alarm and map
I recently picked up a used S3 , a 2006. The PO said the low fuel light didn't come on at all so he used the ODO. I finally got around to reading the codes on it and found none. I also found it was using map 20272. It runs quite rich. I was wondering if anyone has experience with this tune and had problems with the low fuel light not working?
Forgot to mention it has after market dual high exhaust, scorpion. The O2 sensor is still installed.
